What is the thickness/diameter of the rear sway bar on a G?
Old Jan 5, 2014 | 10:16 PM
Rinaldi's Avatar
I am looking to do the rear sway bar swap and wanted to know the thickness of the standard or S model G. I have an X model and I know the non X model sways fit my car but wanting to know the diameter since there are aftermarkets available as well.
Old Jan 6, 2014 | 04:49 PM
Gismyluv's Avatar
I think they are 24.2mm.
Old Jan 6, 2014 | 07:34 PM
G2B35AGN's Avatar
Search the forum. There is a thread with the '07+ sway OEM dimensions as well as the aftermarket sway dims. Nothing on the 05-06 sways, unfortunately, which is what I'm interested in.
Old Jan 7, 2014 | 09:44 PM
blnewt's Avatar
Here's both rear sways that I own, the dirty one is a Journey sway and the other is an S sway (both from 07+G Sedans). The OD is the same, I think the wall thickness of the S sway is a bit thicker but if so it's very minimal as the weight is almost the same. It mic'd at 24.5mm
Old Jan 8, 2014 | 07:37 AM
Rinaldi's Avatar
Thank you.
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
TreeFiddy
Aug 10, 2015 06:50 PM
wuppiedog
Aug 7, 2015 11:16 AM
