2007 Sedan G35 - Wheels
Old Apr 4, 2014 | 09:37 AM
Venecol's Avatar
I would like to put new wheels to my g35... As I mentioned in the title is a 2007 Sedan. I still have the factory wheels and I was thinking to get Vossen vvs084 20" 10.5 on the back and 20" 9 on the front. Do I need to change any other parts to make work correctly? Do you recommend other wheels or sizes? I have never done this before (The car has all his original parts). I appreciate all the help I can get.
How long the tires will last?
Thank you very much
Old Apr 4, 2014 | 10:36 AM
pdexta's Avatar
If you're able to fit those rear wheels at all it's going to be some significant body and suspension work. They're well outside of what a novice wants to even consider putting on their car. When looking at wheels you need to look at the height, width, and offset (how far in/out the wheel sits). This is a really nice calculator that you can plug the specs into and get an idea how it will fit: http://www.1010tires.com/Tools/Wheel...ulator#Results
The stock wheel width on your car is 7.5" and the offset is +45. You can play with the calculator and get an idea how much a different wheel is going to sit in/out compared to stock. You want to stay close to the same "inner position" (+10mm to -25mm should be ok) and no more than +25mm on the "outer position" unless you really know what you're doing.
Old Apr 4, 2014 | 03:36 PM
ProKiller's Avatar
that link isn't bad, but this one is a better. it allows to you also play with tire size.
http://www.rimsntires.com/specspro.jsp
check out the sticky for wheel sizes and you can get a good idea of what will fit and then you can decide on a size.
Old Apr 22, 2014 | 01:28 AM
Jprevo916's Avatar
Another thing to consider on rims if you ever decide to upgrade brake system will they clear calipers? Also if your going to lower the car camber kit.
http://i1304.photobucket.com/albums/...ps4d6e11c1.jpg
Old Apr 23, 2014 | 12:03 PM
PiKapp's Avatar
As nice as it would be to have 10.5's in the back, that's just too wide for our cars, unless you make modifications.
Old May 3, 2014 | 07:23 PM
mistanave's Avatar
i have 10.5's on the back of my '07 no modifications...
Attached Thumbnails 2007 Sedan G35 - Wheels-iphone-166.jpg   2007 Sedan G35 - Wheels-iphone-195-edited-.jpg   2007 Sedan G35 - Wheels-iphone-179.jpg
Old May 3, 2014 | 07:36 PM
PiKapp's Avatar
Oh wow, any spacers or anything?
Old May 3, 2014 | 07:45 PM
mistanave's Avatar
none whatsoever. they're 20 x 10.5 +48 on the rears and 20 x 9.5 +40 on the fronts (looking back at it, I could've gone slightly more on the offset for the front to get completely flush).
Old May 13, 2014 | 07:21 PM
Venecol's Avatar
thank you very much for the info... Any suggestion where to buy the rims?
I also need to get headlights... Mine got really ugly and they have cracks... Where can I get them? I saw them online for $400+/- per piece....
Venecol's Avatar
Wow... it looks really nice... how is the driving? it feels good?
Old May 13, 2014 | 07:32 PM
Venecol's Avatar
It looks amazing... I really want to get 20"s but I can also go with 19"... any suggestions?
Old May 13, 2014 | 10:39 PM
blnewt's Avatar
If you're not going to lower your suspension I'd go w/ 19s and 10.5s will poke a bit at stock height. I have 10" +45 running 295/30/20s but I'm dropped to zero gap on coils. I'd run 10" +45 19s w/ 275/35/19 tires if you keep it stock.
http://imageshack.com/a/img266/1463/1002053q.jpg
Old May 14, 2014 | 11:49 AM
huddledtoast's Avatar
I have 20x10 +40 rears with 275/30 tires and the fitment is just about perfect. Nearly no poke on stock suspension. I posted a pic in the sedans with a/m wheels thread if you're interested.
Old Jun 2, 2014 | 09:41 PM
Venecol's Avatar
I would like to know if these wheels are going to be good for my 2007 g35 sedan ... I am looking to have my car like this one on the pic, this is a newer car, and it has 20" instead of the 19" I am planning to get... Any suggestions?... I am looking for that kind of look... please help... wheels dont need to be vossen, but that is the style I want... what do I need to do?
Item specifics
Condition:
New: A brand-new, unused, unopened, undamaged item in its original packaging (where packaging is applicable).
Rim Brand:
Vossen
Bolt Pattern:
5x120
Manufacturer Part Number:
83-9B03 +30, 83-9B05 +22
Hub Bore:
72.56
Rim Material:
Alloy
Front Diameter:
19
Rim Width:
8.5
Front Width:
8.5
Rim Diameter:
19
Rear Diameter:
19
Offset:
30
Rear Width:
Number of Bolts:
Old Jun 11, 2014 | 08:49 PM
mistanave's Avatar
i personally like work wheels so i've had to order them from japan through authorized work dealers. my first set of works were the vs-xx on an '03 coupe which a friend of mine ordered as he was a dealer at the time. the set on my sedan (gnosis 2) i purchased through a dealer in illinois - touge factory. they had the best pricing on the set i liked. so find a set of wheels you like and then start pricing through dealers that can get you the brand you want. there are some on the forum as well.
as for headlights, i was able to snag a brand new passenger side 07 headlamp w/ afs for $386 on ebay. i had been searching over a year to replace my badly yellowed headlamps. for my driver side light, i lucked out and the dealer replaced it for free when my infiniti manager and i got to talking about some slight imperfections in the bumper/fender alignment one day and then she suggested i take it to their body shop to see if it had been in a fender bender (i bought it certified used with a "clean" history). turned out the driver headlight was basically shattered and had been glued back together, possibly from a collision from the original owner.
Jusseth
Sep 13, 2020 12:25 PM
teamghost
Jul 28, 2015 04:52 PM
laksjd84
Jul 24, 2015 05:12 PM
