I know the breaks are due for a service, and they will be getting lubed up and inspected next week.
I noticed over the last few weeks the rear driver rotor is hotter than normal so the pads are probably dragging a bit. Also this started to happen a few days ago on the rear passenger side. Car is in neutral and there is no load on the suspension or transmission. Also the rear pasenger window is down and the car is parked 2 feet from the garage wall so the sound is much louder for the video.
I am thinking they are just dry and dirty?
There seems to no performance issue that I can notice.
Anyone had this before?
It sounds like that pads are loose in the brackets? Idk but you should easily be able to identify the problem by takeing the wheel off and inspecting the brake
