AC Service
Old May 12, 2014 | 04:07 PM
celwin's Avatar
AC Service
My AC no longer blows cool air. How much is a fair price to fix/recharge it?
Old May 12, 2014 | 06:15 PM
Urbanengineer's Avatar
You probably are lacking the freon needed to make your AC cold. Go to an auto parts store and buy some new R-134 and a filler valve.
Old May 12, 2014 | 11:27 PM
infinitidude's Avatar
Have someone check your ac compressor. These are beginning to be more and more common on the V36 models, especially 07-08 sedans.
Old May 24, 2014 | 02:20 PM
celwin's Avatar
Yep. Had the system checked and the compressor needs to be replaced. How much do they go for?
Old May 24, 2014 | 05:37 PM
bluedevils95's Avatar
The dealers are going to charge me $140 for it. Would be nice if it was cheaper but i guess it's already cheaper then the Torrance dealers
Old May 24, 2014 | 09:30 PM
willdogs's Avatar
If it's not blowing clod anymore, most likely your compressor is toast or you have a leak somewhere. Adding more freon will not fix it, as an A/C system is a closed system and never needs to be "Topped off". If freon is low or gone, that means you have a hole somewhere.
Get it checked.
Old May 25, 2014 | 10:29 AM
celwin's Avatar
Originally Posted by treacherous
Not sure what a fair repair price is but replacement under my extended warranty last year was close to $2K.
No way I'm going to a dealer to install. I will get the compressor and have the same ac shop that identified that problem install for me. They quoted me $180 to replace it if I bring them the compressor.
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
f22raptor
Mar 18, 2016 08:50 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
