Seat memory buttons...what am I missing
Old Aug 30, 2014 | 04:26 PM
ikari's Avatar
I've never been able to get the seat memory buttons to work in my '07 G35S sedan.
They light up, and appear to 'work' just fine.
I have adjusted my seat, and I believe I programmed a button correctly.
Then I move the seat around randomly, and try to invoke the saved settings. Nothing happens. I press the damn button all kinds of ways and nothing happens
Can someone please explain, in idiot-proof logic, how to program a memory button AND activate it??
I want it from you because I've looked up the process and can't manage to do it.
Old Aug 30, 2014 | 05:46 PM
Jrri's Avatar
Do you need to have the parking brake set to get the memory button to work?
Old Aug 30, 2014 | 09:21 PM
G35S.6.0.4's Avatar
No, the car just needs to be in park.
Old Aug 30, 2014 | 09:36 PM
ikari's Avatar
Originally Posted by treacherous
All you have to do is press the SET button and then push the number you wish to assign settings. IIRC it will flash a couple times after 5-10 seconds once set. You need to hold the number button until you see the flashing though. If this doesn't work you have a repair issue at hand.
I guess I do, then... programming appears to work but no link between buttons and seat motors.
Old Aug 31, 2014 | 09:14 AM
Jrri's Avatar
My car doesn't have Park.
Mine won't set the memory if the parking brake is not engaged. I think I found the information on this sight.
Worst case, go test drive one and have the salesman show you how it works.
Old Sep 2, 2014 | 01:28 PM
stockae92's Avatar
What's "park"? Mine has 1-2-3-4-5-6-R ... ;-)
anyway, setting the parking brake will do it for sure
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
dcsbh1
Oct 1, 2015 03:15 PM
doakley92
Sep 25, 2015 12:58 PM
