Automatic Shifter Replacement
Old Oct 1, 2014 | 01:56 PM
beto4632's Avatar
Question Automatic Shifter Replacement
I need to replace my AT shifter on my G35X and i was wondering if the shifter differs on the 07+ models would a g37 shifter work just fine i know that the G37 09+ have the 7AT will that matter.
LIke a G35S or G37S or Base model.
Old Oct 1, 2014 | 03:17 PM
Austin713's Avatar
why do you need to replace your shifter? shift **** or the entire thing?
Old Oct 1, 2014 | 04:54 PM
beto4632's Avatar
Im having problems with it locking in park when parked uphill or downhill, the dealer quoted me at $680 for a full replacement but I found the assembly online cheap, just dont know if there interchangeable by model or type
Old Oct 8, 2014 | 01:20 PM
Austin713's Avatar
take your car elsewhere than the dealer for out of warranty repairs. it will be a hell of alot less expensive.
Old Oct 10, 2014 | 02:33 AM
beto4632's Avatar
Fixed the problem myself, hardest part was getting the G on the ramps.
There is a rod that connects from the shift assembly to the transition, there is a bolt on the AWD that slides so i moved it back toward the rear of the car and now it fully locks in place and it even feels better even when switching over to DS mode. Saved myself $600+
Old Jan 5, 2015 | 09:38 PM
late's Avatar
I encounter same problem today... I didn't have to buy another assembly, there's a rod looking (zinc plated) that moves along with the shifter itself, on the park position that rod should move up along with the white plastic, but the rod was not lining up with the grove which prevented the white plastic to move up as well. The rod was actually bent, I bent my accidentally when I bought some copper material on a tubing package that was too long for the trunk... so I put it through the back seat and protect my leather with my sweater... but when i applied the brake.. the tubing package slid and hit the shifter. It didn't seem hard at impact, but enough to bend that rod. I could see the dealer mention that it could be abusive if you actually hit the shifter hard or push it hard and hit the "R" stopper.
Old Sep 7, 2021 | 01:32 PM
retroo_'s Avatar
all wheel drive g35 sedan
How did you fix the plastic piece that wouldn’t slide to top
how did you end up fixing it ?
xluke
Jul 30, 2016 01:48 PM
JG_G35
Accessories
Feb 25, 2016 01:44 AM
BasquiatPicasso
Jul 23, 2015 06:26 PM
Cskeet
Jul 21, 2015 05:48 PM
newbdriver01
Jul 15, 2015 06:10 PM
