the dreaded via off, brake, and abs light
Old Mar 18, 2015 | 09:52 PM
G35xdriver04's Avatar
So I've done a ton of research on this topic and on my 08 g35x, it seems to come and go whenever it wants. The brake fluid is on max and all pads, rotors are good.
I've read that the throttle body could cause this? I am waiting for the gaskets from nissan. I have rough idle so I do need to clean them. Would this make those lights go off?
I've also read that it could be a bad abs Sensor. Is there a way to check a bad abs sensor?
Any other options I should take?
Old Mar 19, 2015 | 06:18 PM
How do you check to see if your brake light switch is bad?
The three lights only come on when I am braking. And only a certain times. Someday's I'll go a week without the lights coming on, others I'll go a few hours.
I don't think that it would be a bad ABS sensor as the lights would be on almost constantly.
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
mike730
Jan 12, 2018 04:25 PM
miata007
Aug 17, 2015 04:36 PM
Lsantana757
Jul 20, 2015 09:08 AM
