Another vibration question
Old Jun 25, 2015 | 09:53 AM
gary c's Avatar
Gotta love the Stealership and their "that's normal" attitudes! For every issues there's always a solution, even if it's driving it off a cliff!
Gary
Old Jun 25, 2015 | 10:51 PM
tbear35's Avatar
Gary
You would think they would want to make money rather than make a half-hearted attempt.
Old Jun 25, 2015 | 11:20 PM
ScraggleRock's Avatar
Originally Posted by tbear35
I still have the original driveshaft so I checked it out. The joints click when they are pointing straight/level. Also, the bearing for some reason didn't look entirely round. The flex disk at the end looked okay though.
Damnit..wish I had seen this thread before you bought a new drive shaft.
The U joints should be replaceable, and yer drive shaft can be rebalanced (just like a tire). I've done it on other cars and its a fraction of the cost of a new DS.
Old Jun 26, 2015 | 12:40 AM
vqsmile's Avatar
Unless it's gotten bent or lost a weight, a drive shaft should not go out of balance. It's more likely that, for whatever reason, the drive shaft has been disconnected and then reconnected in the wrong orientation (i.e. you are supposed to make re-orientation marks whenever it is disconnected!).
Old Jun 26, 2015 | 12:59 AM
Yes, exactly. If it wasn't marked, it is a possibility.
Old Jun 26, 2015 | 09:06 AM
tbear35's Avatar
I thought the u joints weren't replaceable. I figured by the time I had it balanced and the center bearing replaced (since it was out of car anyway) that it would cost as much as a new driveshaft. I was probably incorrect in those assumptions.
Old Jul 1, 2015 | 09:08 AM
tbear35's Avatar
Well, the car apparently was hit in the rear so maybe that affected it.
Everything seems pretty normal now, the only shudder I get is around 60mph when I let off the throttle. I cleaned the throttle body months ago. Guess I'll try to see if cleaning the MAF and then resetting it helps with that.
Old Jul 8, 2015 | 08:22 AM
tbear35's Avatar
Nope, that didn't work. I'll try a high speed wheel balance at the specialty shop near me.
Old Jul 11, 2015 | 04:08 PM
tbear35's Avatar
Final wrap up. Took to local specialty shop where they roadforce balanced tires (new Michelins). Was told that one tire was like an egg. Took the car back to Discount Tire and they ordered a new tire for me - no questions asked. Guess Michelins can have problems just like everyone else.
Old Jul 14, 2015 | 06:20 PM
esotericrider's Avatar
Glad you finally figured out your problem. I have been dealing with my own virbration/humming issues lately. Thought it was a wheel bearing but those act fine, I narrowed it down to the cheap tires that came with the car. Had them rotated and balanced a few months ago but I guess they are just REALLY loud tires. I am saving up to buy some Bridgestone Turanza Serenity Plus. Just debating on if I should upgrade to 19 inch rims for the G.
Old Jul 14, 2015 | 08:19 PM
tbear35's Avatar
Thanks. Rides like a new car now. Smooth. Originally the car had some off brand tires and the ride was much improved with the Michelins but still not perfect. Glad the shop told me what the problem was and Discount Tire fixed it for me.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
j_mullet
Aug 26, 2015 10:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
