want to drop my 07x
Old Mar 27, 2016 | 09:55 PM
youngdip631's Avatar
want to drop my 07x
Whats up guys i want to cop some eibach springs but dont know if i need anything else such as a rear/front camber kit, control arms or anything like that. Ive read that ill definitely need a rear camber kit but only if i go real low with the springs (which i want to do). Could i just get the springs installed and go from there? Ive read that im going to need to keep an eye on tread wear but what else is there to worry about?
Old Mar 29, 2016 | 02:44 AM
MistrDough's Avatar
Depending on how much you lower your car, you'll change the camber and toe. You can run with that but like you stated, you'll have increase tire wear. You can get new adjustable toe bolts for very little money. You just have to elongate the hole.
Also be careful when lowering your car if it has a lot of miles, it puts more strain on the entire suspension in general and can cause faster wear on ball joints and such. Changing out your control arms will remedy that.
silversleeper
Steering & Suspension
11
Aug 23, 2016 02:05 PM
Rawrster
Mar 30, 2016 01:28 PM
Detailed Image
Mar 23, 2016 04:17 PM
JayVQ
Feb 27, 2016 02:35 PM
