Aux
Old Jul 22, 2016 | 02:10 PM
gwm30900's Avatar
Aux
I have recently bought a 2007 G35x and notice there was no aux port. After looking into I found out you have to use the RCA ports to play music through the aux. So I we out and bought the cord I need to play music after trying to different RCA to 3.5mm I have still yet to get anything to play. All I hear is static when I plug it in. Has anyone else ran into this problem or know what else I could try?
Old Jul 22, 2016 | 04:01 PM
l3fty's Avatar
Look up bc-06 Bluetooth units. It plugs into your car lighter can connect phone via Bluetooth or aux on side of the unit. I'll post some pics later when I'm near my car.
https://www.amazon.com/MFEEL-Perform.../dp/B00ZZGE0SW
Old Jul 23, 2016 | 08:47 AM
willdogs's Avatar
Are you using a cable like this? https://www.amazon.com/Belkin-Audio-...rds=aux+to+RCA
Also are you connecting the RED to RED and WHITE to WHITE? (Yellow is for video signal only)
Lastly you need to choose the AUX input on the radio.
I know all silly question but just double checking because not everyone know the above.
If that doesn't work, I would get another set of cables since they are cheap to rule out a bad cable set. If still nothing then something is wrong with your RCA Inputs.
Old Jul 24, 2016 | 10:31 PM
l3fty's Avatar
Wouldnt it jsut be easier to get the unit i posted above for twenty bucks ? includes phones and music of your ipod/iphone.. been using it for six months at this point havent had a single issue with it
Old Jul 24, 2016 | 10:40 PM
willdogs's Avatar
Yes if that's what he/she wants. It's good to have options.
Also Wired connection will always have better sound quality over the device you posted.
Old Jul 25, 2016 | 04:36 PM
dookie's Avatar
if you are using one of the R/W/Y cables, you might need to swap the yellow with a red or white connection as some of those cables are actually for specific devices and thus are wired slightly different.
Also, you might have a cable that's incorrect for your media player. Some devices use different phono jack layouts. You should try out your cable on a home stereo or something else with an audio input to see if it works there.
G35NBOOB
Jul 22, 2016 02:48 PM
IAreBob
Jul 21, 2016 05:30 PM
slcg35x
V36 Brakes, Suspension, Wheels & Tires
Jul 21, 2016 04:20 PM
gthangbby
Jul 21, 2016 03:02 PM
G35shotta
Jul 19, 2016 02:53 PM
