Trunk open indicator
Old Sep 11, 2016 | 10:46 AM
celwin's Avatar
My trunk open indicator warning stopped working. I recently removed glove box to replace cabin filter. All harnesses were reconnected. Any ideas?
Old Sep 11, 2016 | 11:53 AM
BradMD_96's Avatar
Does the trunk open switch (by the VDC button) still work?
If not you might have knocked off the connector for that switch - which is inside the glove box.
Not sure if that would cause the light to stop working but it's the only switch that relates to the trunk in that particular area.
Old Sep 11, 2016 | 01:45 PM
vqsmile's Avatar
There is a "TRUNK RELEASE POWER CANCEL SWITCH" located in the glove box. (ref: Owners Manual page 3-19 or so) Perhaps it got unplugged and is causing the problem. It's the most obvious thing I can think of that would correlate the glove box with trunk functions. I always look for the easy stuff first.
.02
Old Sep 12, 2016 | 08:12 AM
celwin's Avatar
Yes that works fine
Old Sep 12, 2016 | 08:14 AM
celwin's Avatar
.02
I will double chec that; But if this was disconnected, wouldn't the trunk not open at all
Old Sep 12, 2016 | 11:33 AM
vqsmile's Avatar
Well, it may not necessarily be disconnected, it could be pinched/shorted or something. There are so many "intelligent" controllers behind the scenes in these cars that even something as simple as a switch may in fact be more involved than expected.
I agree though, it doesn't seem like it should. It's just so strongly suggested as a likely suspect from a purely troubleshooting step, since it does have a related function AND it was possibly disturbed by the work you last did before it quit working.
Old Sep 25, 2016 | 10:18 AM
celwin's Avatar
As strangely as it started, it just as strangely began working with me doing nothing. Oh well, gremlins I guess.
Benja455
Sep 12, 2016 06:59 PM
2003G35JDM
Sep 10, 2016 05:53 AM
iMightBe
Sep 8, 2016 03:26 PM
TrueG35
Aug 31, 2016 10:28 AM
Magnum8
Aug 20, 2016 01:03 PM
