P1705 Code - Question
Old Dec 7, 2016 | 05:12 PM
Deuces88's Avatar
have a P1705 code for throttle position sensor circuit.
Cold start i have a very slight rough idle, also in lower gears i have a slight hesitation. Clearing the codes and resetting the ecu helped alot. However the problem still seems to occasionally happen.
Question is this something i can replace myself? Should i try cleaning it first. I inspected the throttle body and it seems like the sensors are pretty easy to get to.
I have a 2007 g35x btw.
Thanks for any help. Have my car for a couple weeks now. Other than this little issue its been awesome. Had a private mechanic tell me cars in excellent shape.
Old Dec 8, 2016 | 01:13 AM
Deuces88's Avatar
Bump for any possible answers!?
I cleared the code when it came up. I'm not sure if its still there. I have to use my friends code reader on friday to find out.
I already disconnected my battery overnight and that def seemed to help a bit. Should i try the throttle relearn?
Unplug the sensor and plug back in? Not sure what to do!!
Old Dec 8, 2016 | 10:43 PM
hahalife's Avatar
As others have mentioned in similar threads, I would clean the throttle bodies /maf sensor. Should be good to go.
