2007 G35 Won't blow any air from the vents after being turned on in the morning
Old Sep 13, 2017 | 08:48 PM
Nyy8's Avatar
Hi all,
I have a 2007 G35, and I have just recently started to have this issue where the vents won't blow any type of air when I first start the car in the morning.
Whether it's 65 degree AC or 80 degree heat, I get no air at all. After about 15 mins into my drive or so, the air will randomly come on when it pleases, and work great the rest of my drive. If I have it set to AC, it will blow cold, and heat will blow hot.
It's also very temperamental... some mornings the air will come on, most of the days, it won't.
Now, I noticed when I turn the AC on and no air is blowing out of the vents, I can hear the compressor turn on.
So far, I have replaced the blower motor relay, as suggested by forum members. But this has not solved the issue, instead of just throwing parts at it, I thought I'd ask here first to see if anyone has any ideas.
Thanks
EDIT;
Little detail I left out, that may help you out.
So, Let's say I turn the car off with the climate control at full blast, and then I turn the car back on.
You can hear the climate control start to ramp up, back to where it was, then it cuts itself out. Just something odd I noticed.
Old Sep 13, 2017 | 09:12 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Edit: well scrap everything I said, apparently you already changed the relay... did you verify it was the correct relay? There are 2 or 3 depending on options and they are all the same relay and next to one another.
On​​​ the back side of the fuse panel next to your left foot there are a couple of blue relays, you have to remove the two bolts holding the fuse panel in place to access it. One of them is the AC fan blower relay, check the FSM to find out which one is for that fan and replace it.
Takes about 10 minutes, remove the left foot rest, remove the trim plastic over the fuse holder (all of it, the entire kick panel), unbolt the fuse holder, swap the relay.
Old Sep 13, 2017 | 09:16 PM
Nyy8's Avatar
I bought the part straight from Nissan, it was 25230-79942 Blower Motor Relay.
It was under the foot pedal, like you said, I removed the bottom relay, when the car was on to test, it controlled the dashboard gauge cluster light and the blower motor. This was the relay I replaced.
Old Sep 13, 2017 | 09:19 PM
cleric670's Avatar
BANNED!!!
I would focus troubleshooting on the blower motor itself then. If you have the factory stereo you can do the self diagnosis for the AC controller, not an option if you have an aftermarket stereo.
Old Sep 13, 2017 | 09:21 PM
Nyy8's Avatar
How would I do this? I have the factory setup with Navigation/Tech Package.
A quick google search leaves me with some older threads where the instructions aren't as clear
Old Sep 13, 2017 | 09:50 PM
cleric670's Avatar
BANNED!!!
Page 83 covers the motor
http://www.nicoclub.com/service-manu..._G35_Sedan/hac
Page 93 just to confirm that yes THIS was the relay you replaced.
http://www.nicoclub.com/service-manu...7_G35_Sedan/pg
Apparently they did away with the self diagnostic for 2007? I don't see any mention of it in the FSM anymore? The troubleshooting steps are basically, turn on fan, if it's not working unplug the 3-wire motor harness and test for 12v battery voltage, check for ground, check for continuity on the to the unified meter/ac amp...
Old Sep 13, 2017 | 10:02 PM
Nyy8's Avatar
Let me ask you this, I am 99% confident I pulled the relay from the bottom.
When I pulled the blower relay, the blower (which was working at the time) turned off and so did the lights on the gauge cluster.
If I had pulled the accessory relay, would the blower have turned off from the accessory relay being pulled?
Old Sep 13, 2017 | 11:10 PM
cleric670's Avatar
BANNED!!!
It should not affect ANYTHING on the instrument cluster I believe. I did the same thing on my vehicle and literally there was no change except for the blower motor not running.
Mine is an '06 coupe though, but I think you replaced the wrong relay. The diagram is looking from the back side.
Old Mar 16, 2018 | 03:17 PM
Domls1972's Avatar
Same issue
Hi Guys
i am am having the same issue where the fan won’t blow are till the car worms up after 20 mins. I replace the relay which was the top on my 07 G35X sedan. I noticed when I kick the fuse panel a few times it comes on but then shuts off then I do it a second time and it seems to stay on. Any ideas on what this issue is ?. Thanks
Old Mar 16, 2018 | 03:31 PM
cleric670's Avatar
BANNED!!!
Definitely sounds like a relay, are you sure you replaced the right one? Check the FSM and under the section for Fuse Block - J/B it will have the relay diagram for the back of that panel.
edit: section PG of the FSM, Power and Grounding.
Old Mar 16, 2018 | 03:39 PM
Domls1972's Avatar
Pretty sure I did but I’ll check again. Do you have a link ?
Definitely sounds
Old Mar 16, 2018 | 05:29 PM
cleric670's Avatar
BANNED!!!
http://www.nicoclub.com/FSM/G35/Sedan/2007_G35_Sedan/
Section PG, page 93. You can see the "blower relay" is the one on the far end opposite of the ignition relay.
Old Nov 28, 2018 | 10:23 PM
Dalia Fuentes's Avatar
n/a
Hi did you resolve this issue? About 3 months ago my a/c heater stopped working. (Doesn’t blow out any air no matter what) the defroster in the back still works. It’s starting to get cold so I’ve been trying to work on it. I changed the 2 15A fuses by the drivers side fuse box and they seem to keep blowing out. I bought a new blower motor relay, I replaced it by removing the two screws on the fuse box on the drivers side and replacing the relay closest to the floor. I think I replaced the right one. I replaced it and replaced the two 15A fuses again but still no luck. I’m stuck now pleaseeeee help! Thank you!
Old Dec 4, 2018 | 11:34 PM
Urbanengineer's Avatar
Does it blow cold either? If not, test everything related to the fan. Sadly it seems like it could be your blower motor (ac fan).
Old Dec 5, 2018 | 11:39 PM
n/a
thanks for replying! No air blows out what so ever. I just ordered a blower fan and I’ll swap it out this weekend hopefully that’s it! I tried replacing the relay but that don’t work out. Hopefully replacing the blower motor works. It’s freezing on the east coast!
