Getting vibrating/rattling noise from engine?
Old Apr 22, 2018 | 12:11 PM
Kb24great's Avatar
Hey guys, I just got a used g35x, and now I hear a vibrating rattling noise from the engine. I am automatically assuming the worst and thinking it has to do with the timing chain. Can you guys give me some input?
Old Apr 22, 2018 | 08:32 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like the heat shields on the exhaust. Get under it with a mechanics stethoscope and poke around for the noise, if getting under the vehicle while it's running is a problem then find a local lube shop that will let you use their pit for a couple minutes. Throwing money at them always works, especially if they don't have customers waiting.
Old Apr 23, 2018 | 06:05 PM
Kb24great's Avatar
Thanks for the reply! I’ll definitely check that
Old Apr 24, 2019 | 12:58 AM
hampton_25's Avatar
Did you ever get a resolution on this? Pretty sure I'm having the same problem.
Doug
Old Apr 24, 2019 | 02:31 AM
Kb24great's Avatar
https://www.youtube.com/watch?v=II45twXg6Vw
Doug
Yup, one of my cats were bad so that was making noise and I had a exhaust leak on my y pipe making noise too
edit: just listened to your video. It sounds like one or maybe both your cats are bad. The honeycomb or whatever is loose and rattling inside. Atleast that’s what it sounds like to me
Old Apr 24, 2019 | 09:48 AM
hampton_25's Avatar
Thanks for the quick reply. Going to put her in the shop this week to see what they say.
Doug
Old Apr 28, 2019 | 12:28 PM
$KYLINE's Avatar
I'm so thankful for this post. I developed the same noise before my car went into storage last year and i was afraid that it was piston pin/bearing clearance or chain noise. My y-pipe has seen better days so at first i thought it was an exhaust leak but I can't really feel it.
Definitely share your results!
Old Apr 28, 2019 | 12:30 PM
hampton_25's Avatar
Confirmed it's at bad cat on driver's side. No codes or CEL, so just going to keep driving it for now.
Kb24great
V36 Engine, Exhaust, Drivetrain & FI
Apr 22, 2018 08:33 PM
Ryuu
Aug 26, 2011 03:36 AM
Theanimedude
Oct 7, 2010 09:22 AM
josephjochoa
Sep 26, 2009 05:42 PM
CONCRETE
Drivetrain
Jul 26, 2007 08:36 PM
