rack & pinion seal kit or remanufactured unit?
Old Jul 26, 2018 | 08:34 AM
timothymiles's Avatar
My 2004 G35x rack and pinion is leaking a lot so I need to do something. The remanufactured units are expensive yet I can purchase a seal kit for around $40. Is this a job that can save me money and be performed by a competent mechanic (not at the dealership) or am I better off biting the bullet and going with the remanufactured unit and letting my mechanic do the R&R?
Old Jul 26, 2018 | 09:26 AM
Urbanengineer's Avatar
I just bought the Reman option with the inner tie rods attached.
Old Jul 26, 2018 | 12:24 PM
coffeysm's Avatar
I'd go with a reman and check out rackdoctor.net you might be able to get a good for 200-400 bucks I think. I've done research on this with my Audi and it's a lot of labor and work replacing the seals without proper tools and if you make one small mistake it will leak again.
Old Jul 28, 2018 | 12:58 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The last R&P rebuild I did took like 10 hours because everything was badly seized up, if your R&P LOOKS corroded I would definitely go with the remanufactured unit. If you're just swapping inner/outer tie rod ends though that is MUCH quicker than doing a full bearing/seal/bushing kit.
therrin4
Drivetrain
Nov 21, 2017 07:21 AM
NISMO500
Steering & Suspension
Feb 18, 2012 09:59 AM
Marlin
Nov 15, 2009 12:14 AM
Marlin
Nov 12, 2009 04:51 PM
