Rear driver window won’t work
Old Jan 13, 2019 | 01:49 PM
CollinWoodyard's Avatar
silver with gunmetal gray wheels, sunroof, stock height, stock everything
Hi I got an 07 g35 sedan and the rear driver window isn’t working. It’s rebuilt cuz was hit in rear driver side(already been fixed and painted). I hooked up a new motor and stil nothing. Both switches aren’t moving it either. Is there a relay or ground I can check
Old Jan 13, 2019 | 03:51 PM
telcoman's Avatar
Veteran: Army
Grab your multimeter
There is a FSM that you can check the harness and voltages
https://www.nicoclub.com/FSM/G35/Sed..._Sedan/pwc.pdf
See page PWC-18
Rear Power Window Switch power Supply Circuit Check1.CHECK POWER SUPPLY CIRCUIT1. Turn ignition switch ON.2. Check voltage between rear power window switch connector and ground.Is the measurement value within the specification?YES>> GO TO 3.NO>> GO TO 2.Te r m i n a lVoltage (V)(Approx.)(+)(–)Rear power window switchTerminalLHD5410GroundBattery
Telcoman
Old Jan 13, 2019 | 05:14 PM
Blue Dream's Avatar
I drove ttrank's car solo
And please post threads in the appropriate sub-forums, I've moved this one for you.
Old Jan 16, 2019 | 09:25 PM
Thank you that page helped a lot. Thanks for moving it and won’t happen again
Saxon_Ryan
Sep 17, 2013 11:19 AM
develop1
Jan 11, 2013 11:20 AM
marvinp8700
Jun 15, 2009 12:45 PM
CalsonicVQ
Mar 14, 2007 01:28 PM
Drewer
Jan 27, 2004 01:11 AM
