Please Help me out?!
Can someone help me please? I have had oil leaking into my Spark Plugs from both side, passenger side being excessive. I bought the OEM Valve cover gasket but they did not give me the O rings? What am i supposed to do? When i called them up they said you cant replace them anyway it is within the Valve Cover. Any help please?!
I believe they're built in to the valve covers, but I haven't done a VC replacement so I'm not sure. You may have to drill them out and find some new custom seals. Pretty sure there are a few threads on it floating around these forums.
It can be done but it requires you to drill out the retaining plastic on the valve covers so you can remove the old gaskets. Some folks have had success by just using Permatex Ultra Grey RTV on the existing spark plug well gasket and just reinstalling the valve covers with a new VC gasket (or more permatex). If you do make sure to thoroughly clean the surfaces of any oil and let the RTV cure for 24 hours before starting the engine (based on ambient temp, in cold weather wait 48 hours).
Or you can buy new valve covers.
yosip1115
Aug 20, 2015 10:30 PM
