Thread Count for Tow Hook Same for 2008 X Models? (Front License Plate Bracket)
Old Apr 8, 2019 | 01:00 PM
MING35x's Avatar
G35x Sedan Sport
I bought the bracket from Stillen for my front license plate because I do not want to destroy the bumper by drilling holes in it. Stillen said they are unsure whether the thread of the bracket which fits the coupe is the same thread for the X models as well so the order is on hold for now while we research. I have a 2008 G35XS.
https://www.stillen.com/exterior/ext...initi-g35.html
Any ideas?
Thanks.
Old Apr 8, 2019 | 02:34 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Take your tow hook and measure it then tell them what size it is.
Old Apr 8, 2019 | 02:58 PM
MING35x's Avatar
G35x Sedan Sport
Measure the inner diameter? How would I be able to pop-off the plastic cover in front of tow hook so I can get to it? I try pushing it a bit but I wouldn't budge.
Old Apr 8, 2019 | 04:14 PM
MooseLucifer's Avatar
5 Year Member
blk
There should be a small space at the bottom to stick a flathead screw driver, it will pop out towards you, away from the bumper.
Old Apr 8, 2019 | 04:16 PM
MING35x's Avatar
G35x Sedan Sport
That makes sense now. Yea, there was a small space. Thanks! I'll give it a look tonight.
Old Apr 8, 2019 | 04:55 PM
Joenavy85's Avatar
G35x Base
pop the trunk and pull up the mat, the foam over your spare tire holds the scissor jack, lug nut wrench with extension and the tow ring, measure the threads on it. Unless of course you tossed all of that for more space/less weight, or bought it used and the previous owner ditched it, in which case nevermind
Old Apr 8, 2019 | 05:01 PM
cleric670's Avatar
BANNED!!!
Yeah I was talking about measuring your actual tow hook that threads into the hole in the bumper.
Old Apr 8, 2019 | 05:10 PM
Joenavy85's Avatar
G35x Base
I caught that, I just based my comment off the reply to yours. I legit didn't know where the tow hook was (the hook itself) until I had to change a tire.
Old Apr 8, 2019 | 05:35 PM
cleric670's Avatar
BANNED!!!
Yeah when in doubt looking for random stuff like that it's ALWAYS next to the spare tire. Like Ford's with the capless fuel tank, if you need the special funnel it's by the spare tire.
Old Apr 8, 2019 | 07:35 PM
MING35x's Avatar
G35x Sedan Sport
Thanks everyone for the advice! I was able to find the hook in the trunk by the spare tire. I sent pictures of it to Stillen. Hopefully they can make sense of it and see if it will fit...I'll keep you posted.
Old Apr 8, 2019 | 09:10 PM
G2B35AGN's Avatar
Take it to a good hardware store or to a fastener specialty place. They'll have gauges to tell you exactly the diameter, thread count and thread pitches.
Old Apr 11, 2019 | 09:50 AM
Hall Stevenson's Avatar
Will be interesting if they determine the thread size and pitch from a picture. Did you at least measure the O.D. of the fastener ? From that, they can really make an educated guess (thread sizes are standardized, you can visually tell the difference between 'fine' thread and 'coarse' thread, and they'll convert it to mm as well).
Old Apr 11, 2019 | 11:11 AM
MING35x's Avatar
G35x Sedan Sport
They weren't able to determine the size unfortunately. They have directions on how to measure the hook at least. I will try to measure it tonight and send them the info to see what they say. I will keep you all posted!
Old Apr 11, 2019 | 02:57 PM
Take the mating piece from the truck to a hardware store like others have said. They have nuts and bolts mounted on boards with the sizes. Find the "nut" that your tow hook threads into. It will be metric and looking at mine, I'd guess M22 x 2.5.
Old Apr 11, 2019 | 09:12 PM
MING35x's Avatar
G35x Sedan Sport
Clearance from tow hook to front of vehicle.
Took some measurements and sent then over to Stillen. Let's hope it'll fit. I don't want to drill the bumper lol.
Menards said thread pitch is 7/8ths.
