Power Drivers seat, Steering wheel, and mirrors not working?
Old May 22, 2019 | 01:47 PM
Onetimer's Avatar
G35 S Sedan
I just went on a road trip and my power drivers seat, control for steer wheel, and control for my mirrors quit working. When I try to move the steering wheel, I hear a clicking noise but not on the seat and mirrors. I've tried to find a fuse but haven't been able to locate it. Does anyone know where it might be and or this something else that could be causing this?
Thanks!
Old May 22, 2019 | 06:17 PM
lightmeupper's Avatar
G35X
Defiantly sounds like fuse or wiring!
Old May 22, 2019 | 07:35 PM
Onetimer's Avatar
G35 S Sedan
Thanks!
I guess I should have said it’s an 07 g35S sedan.
Old May 22, 2019 | 08:48 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Start at the fusible link on the battery positive post, next check the IPDM, next check the Fuse Block - J/B in the cabin.
Pull every fuse, inspect, replace, one at a time.
I'm on mobile so can't easily pour through the FSM to give you a fuse number.
Old Nov 23, 2020 | 11:44 AM
tswan1206's Avatar
G35s
did you fix your problem? I’m having the same issue .
Old Nov 26, 2020 | 10:18 AM
cleric670's Avatar
BANNED!!!
Ok I just looked up the FSM, probably blew fuse 6 in Fuse Block - J/B the cabin fuse block. That's the only one that does the power mirrors, steering tilt/telescope, and power seat.
Old Nov 26, 2020 | 10:23 AM
tswan1206's Avatar
G35s
my steering power works tho, i checked the fuse and that’s fine . 🤦🏻‍♀️
Old Oct 4, 2021 | 12:19 AM
Mlaferriere77's Avatar
2007 G35x Sedan w/ tech pkg
Power drivers seat, memory seat & pwr mrrs inoperable
Hello, I also have a 2007 G35x sedan , about a week after I bought it in 2019 the drivers side seat , seat memory control, and my power mirrors all stopped working. Although my (driver side)lumbar support & passenger seat still functions. So I purchased a parts car with heavy front end damage. When I power the parts car up , driver seat , memory seat & power mirrors all work. So I took the seat out of parts car and put it in my daily driver & NOTHING!! But if put my seat out of my daily driver in my parts car, the power seat , memory function & power mirrors operate as usual! I've triple checked all the fuses in passenger compartment & under the hood. I was wondering if there is a processor or control module that controls these functions considering they all work in tandem.im at a loss, short of running an auxiliary power source to power up the drivers chair idk what to do! Oh yah I'm in a wheelchair so I kinda got lucky that seat died in a position where I can wiggle my w/c out of car without to much issue. But I really would appreciate any & all suggestions.
Old Oct 7, 2021 | 11:23 PM
cleric670's Avatar
BANNED!!!
There's a computer called the "automatic drive positioner" located under the dash, between the brake and gas pedal, up at the top of them, and it is the interface for both those controls as well as things like the telescope steering adjustment.
I'm fairly sure that's what failed if all your fuses are good.
Old Aug 30, 2024 | 09:39 AM
Jayyy's Avatar
G35X
Thanks!
I know its an old post but did you figure it out. I have exactly the same problem 😞.
Just Cruise
Dec 10, 2015 08:48 PM
rdeol
V36 Interior, Exterior & Lighting
Sep 8, 2010 12:03 PM
PTownG
Apr 16, 2009 07:20 PM
louisdarke
Oct 19, 2006 04:13 PM
