no oil pressure at idle, 222K miles, advice?
Old Aug 6, 2019 | 11:24 AM
Sieveboy's Avatar
Hi, I have a 2007 G35X, 222,000 miles, bought new. Oil changed properly the whole time.
It's now got about 7 psi of oil pressure at idle when hot. Pressure light is on. Goes away with rpm increase.
I took it to a mechanic who put a mechanical oil pressure gauge on the engine through the port where the oil pressure sender is attached.
He advises just drive it, put it in neutral at lights, air-conditioning off, it may last a while as I shop for a new car. He says its probably not even the pump but a combination of things most likely bearing clearances. Pretty much what I expected. I drained the oil and put in 10W-40 and still the same.
Anything else I should do? Any recommendations?
Thanks
Old Aug 6, 2019 | 11:54 AM
Pbfoot's Avatar
04 G35 Sedan performance package. 70k Eibach springs and sway bars. 19 inch wheels. Plenum spacer.
[QUOTE=Sieveboy;7173595]Hi, I have a 2007 G35X, 222,000 miles, bought new. Oil changed properly the whole time.
I didn't have a mechanical oil pressure gauge, so took it to a trusted mechanic.
So he checked with a mechanical gauge?
Old Aug 6, 2019 | 12:09 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Could also be the galley gaskets.
Check out this thread for some ideas on where to start. I highly doubt the mechanic installed a mechanical gauge but maybe he did? Definitely verify and if he did NOT then you probably should have an electric gauge and a new sender at minimum. Preferrably a mechanical.
https://g35driver.com/forums/v36-diy/444884-checking-your-oil-pressure.html
Old Aug 6, 2019 | 12:40 PM
Sieveboy's Avatar
sorry for the confusion, he installed a Snap-On mechanical oil pressure gauge to the port where the sending unit is and it read 7 psi at warm idle
Old Aug 6, 2019 | 03:01 PM
cleric670's Avatar
BANNED!!!
Ok, galley gaskets are a definite cause of low oil pressure. Do you have any trouble codes?, Typically there will be a P0021 / P0011 codes along with it because the cam actuators aren't working with low oil pressure.
Old Aug 7, 2019 | 01:28 PM
Sieveboy's Avatar
Car is not throwing any codes from what I can tell - no lights are on other than the oil light
cfauvel
13
Oct 31, 2016 09:14 AM
Schuma3955
Jan 26, 2012 06:03 PM
bythabay
May 13, 2006 05:31 PM
Wanchu83
Jan 12, 2006 04:46 PM
