All lights on dash are on after changing rear caliper
Old Oct 2, 2019 | 01:58 AM
Admiral420's Avatar
G35s sedan
I changed my driver rear caliper today and now my vacation, slip, brake, service engine soon lights all came on how can I remedy this
Old Oct 2, 2019 | 07:56 AM
G2B35AGN's Avatar
This doesn't help you, at all, and I'm sorry but can't resist...
I'd pay to have a vacation light on my dash that stays on all the time. That would make for the perfect daily driver....
Again, my apologies. Thanks for the lovely damn autocorrect. I toast you sir.
Old Oct 2, 2019 | 12:13 PM
Joenavy85's Avatar
G35x Base
I can only assume you originally typed "VDC OFF" and your phone changed it. What all did you mess with when removing and replacing the caliper? Did you by chance damage the ABS Wheel Speed Sensor wire?
Old Oct 2, 2019 | 12:20 PM
Joenavy85's Avatar
G35x Base
Old Oct 2, 2019 | 12:56 PM
Urbanengineer's Avatar
Probably didn't pump the brakes before turning the car back on to push out the caliper. The wheel speed sensor is on the diff
M
Old Oct 2, 2019 | 01:34 PM
Triton3.5's Avatar
Yes, i had to change a bad rear caliper out several years ago, and it was just R&R remove, and replace, my oem one was sticking, and of course baking the rotor, luckily i caught it in time, and the rotor was saved. but the car did not know i had did any thing to it, ie. no lights on the dash or anything..
Old Oct 2, 2019 | 04:30 PM
Hall Stevenson's Avatar
Check your brake fluid level too.
Tessalynn_G35
Aug 27, 2014 05:57 PM
MAXIMA to G35
Nov 3, 2009 08:16 AM
MAXIMA to G35
Nov 2, 2009 09:13 PM
