Weird stutter/hiccup problem. Please read and small reward
Old Dec 3, 2019 | 09:24 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Hitachi for all years.
Old Dec 3, 2019 | 09:28 PM
Joenavy85's Avatar
G35x Base
Gotcha, no go on rock auto, the search continues.
Edit: M35's had identical engines, right? If so, rock auto has the sensors, just have to go to the 08 M35 to find them.
Old Dec 4, 2019 | 01:07 AM
Scorpi0's Avatar
Nissanpartsplus.com is where I found the best prices for sensors. Check em out.
Old Dec 4, 2019 | 10:41 AM
cleric670's Avatar
BANNED!!!
Check with the marketplace vendors, Z1 Motorsports and CZP carry the OEM Nissan sensors in stock. Or get the Hitachi part numbers and just buy them on the internet.
Old Dec 4, 2019 | 06:59 PM
Triton3.5's Avatar
So all you guys think its Cam/crank sensors? My car runs so good except for 2 3 mins post warm up, that i have lived with it like this for heck 4-5 years, car has never had its CEL illuminated. I still don't know what to do about it.....
Old Dec 4, 2019 | 11:33 PM
Scorpi0's Avatar
Cam and crank sensors would definitely illuminate the check engine light though. So thats what makes your issue puzzling. Are u sure your check engine light works?
Old Dec 5, 2019 | 07:27 AM
909's Avatar
909
Your mom's boyfriend
Man you gotta maintain your car better bro .
I know you're broke and in college but still there's no excuse for slacking , might as well be a woman driver.
Start by topping up all your fluids, 9 months is way to long to not pop open your hood.
No offense but I bet your car is dirty .
Change your air filters
Fuel injection cleaner in the tank
Only premium high octane gas
Report back bro.
Old Dec 5, 2019 | 10:06 AM
depmike38's Avatar
5 Year Member
g35X 4dr sedan
My problem was not the result of a CEL. It never tripped and never left a code in diagnostics. I went that route(sensors) because of the information I found here and verified other places about the sensor issue. I replaced them all as insurance and the fix was immediate. Side note: if you have any type leak on the perimeter of the left side valve cover it can sometimes work it's way around to the back and run/drip down to the crankshaft sensor.
Old Dec 5, 2019 | 01:41 PM
cleric670's Avatar
BANNED!!!
Cam sensor intermittent failure usually won't illuminate the CEL, it will store as a hidden DTC that you'll find when you scan the car. If it's a complete failure then it will turn the CEL light on.
First things first, scan the car right after having the problem, self clearing codes like this don't last very long in the ECM memory.
Old Dec 5, 2019 | 06:44 PM
Triton3.5's Avatar
Ok, yes i have not even >ahem< scanned the car so i have to get off my **** and at least see whats stored... The car does it every time i drive it, although it has to be a >cold< start, warm, or hot starts, it does NOT due these, bogs, misses, or hiccups.....
Old Dec 5, 2019 | 10:36 PM
treacherous's Avatar
20 Year Member
G35x
Kinda sounds like an issue I had about 9-10 years ago before getting a flash.
File Type: pdf
Old Dec 6, 2019 | 10:20 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
I haven't seen that TSB but it makes sense. On the 07'-08' G35X cars the first ECU's are a A,B,C revision. I changed my brothers 08' G35x car from a "A" revision ECU to the latest "D" revision ECU and there were quite a few differences. It even rescaled the gas pedal so the car wasn't so jumpy off the start. I also hear there is a TCU update from the 1st gen V36 models too.
Old Dec 6, 2019 | 01:21 PM
20 Year Member
G35x
I had several flashes over the years.... the one above, the over-sensitive throttle, and another for radar cruise throttle going down hill. I can't remember if I am on C or D at this point.
https://x.infinitihelp.com/forum/loc...s.php?catid=71
File Type: pdf
Old Dec 7, 2019 | 11:51 AM
Triton3.5's Avatar
Yes i remember all those, (since i have been on here since almost the beginning) However, i actually liked the hyper sensitive throttle response on these cars since day one, so i never did anything about it.....
Old Dec 7, 2019 | 06:43 PM
  #30
20 Year Member
G35x
I would have but the issues which cropped up on mine were too much for the wife so pursued the flashes. One could always drop a Pedal Commander to increase throttle sensitivity. I have a PC on a GX 460 of all things and on extreme sport setting it feels like stock '07 G35 flash for throttle tip in sensitivity.
