Security light solid on
Old Jan 4, 2020 | 02:32 PM
dedius256's Avatar
V6 black 298hp 160mph
Hey good day please I need help very frustrated I removed my battery from my Infiniti G35x to start another car because the other car battery was weak after i started the car I then returned the battery to my Infiniti I then tried to start the car it cranks but it refused to start. I used the car this morning am so frustrated I don't know what to do I noticed that that the security light stays solid on if I turn the ignition to on is this supposed to be normal or is it a security problem because I tried locking the door with the remote then unlocked it then tried again to start the car it cranks but doesn't start I also detached the key from the remote I put it in the ignition but it doesn't turn the ignition but if I use the remote it turns the ignition please am so frustrated I need help.thanks
Old Jan 4, 2020 | 03:16 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Solid red light WHEN CRANKING THE ENGINE means the car does not recognize the key you are using to start the vehicle. The engine will crank but the injectors will not open and there won't be spark, it's a NATS/IVIS interlock, the anti-theft stuff on the G35.
First try unplugging/reconnecting the battery, if that doesn't work then try resetting NATS by following these steps from the FSM.
Old Jan 4, 2020 | 03:18 PM
cleric670's Avatar
BANNED!!!
If that doesn't work you'll probably need to get the BCM reprogrammed to accept the keys by a locksmith or the dealership.
Old Jan 4, 2020 | 05:03 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
If the key light stays on it can be a couple things. Probably need to have a scan tool capable of resetting the BCM codes first. You also may try putting your FOB in the slot located in the lower dash where your left knee is at and try to start.
Old Jan 4, 2020 | 09:29 PM
cleric670's Avatar
BANNED!!!
OP needs to verify but I was under the impression that he didn't have an intelligent start (push button) system.
djw
Apr 6, 2019 12:37 PM
rickrag
Sep 14, 2017 09:45 AM
05g356spd
Jul 10, 2014 02:04 PM
MADtotheA
Sep 11, 2011 06:37 PM
G-ThreeFizzle
Sep 17, 2005 01:44 PM
