Busted Dash - Need Odometer Readings
Hey guys
I do have a OBD2 connected and I tried 2 apps already.
Torque Pro and OBD Fusion both doesn't have an option to display the odometer for the G35. OBD Fusion does have the widget for odometer but it doesn't work for G35.
Is there an app that works with the G35 for odometer?
Some vehicles the odometer is stored in the ECU and accessible via OBD2. The G35 the information is stored in the instrument cluster itself and NOT accessible via OBD2.
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
If you are replacing the gauge cluster you can swap the flash chip so it reads correctly. That's what I have done in the past.
Thanks everyone. Luckily, it came back alive 90% after driving it for a day. I still want to fix it but it's usable for now and I can see all the info.
There's just one corner that doesn't work.
Hey dude, can you link me to the DIY to do that? Or give me more details on which chip that needs to be swapped? I'm facing the same issue with a busted odometer, and I need to change the gauges but want to keep the original mileage readings.
There isn't a DIY on it but if I can get time I'll pull one out of the garage and take some pics and make some sort of write up.
What is the sticker # on the back of your cluster? IE:JK603, JK60A, JK61D?
Legend! That'd be fantastic if you could do that.
I haven't checked, but I'll pass by the garage where the car, take it off and read what it says there.
It's an 04 G35 Coupe, didn't know there were several options of clusters
EDIT: Woops, I just realized I jumped into the newer G35 section with a completely different dash. Guess it will be different in my case.
Yeah, they are different. I sold all of my old gen stuff and don't have a V35 gauge set anymore. If you open yours up and take pics I can probably still help and point it out. You will also have to have good soldering skills or know a shop that is able to move a SMT 8 pin chip.
