Suspension Problem - sway bar link fix
I put on Hotchkis sway bars and MOOG links on my 07 g35x sedan about a month ago. The rear sway bar is hitting the control arm over bumps. There's a rust spot starting where the bar hits the arm. The MOOG links are shorter than factory but I need even shorter links. Anyone have this issue and have a fix? Or know who makes shorter rear links? Thanks
None. I replaced the shocks and struts at the same time (KYB all around) but I didn't swap springs or adjust the ride height.
MING35x
V36 Brakes, Suspension, Wheels & Tires
14
Apr 29, 2019 10:39 AM
