Sway Bar On G35x??
Old Jan 13, 2005 | 10:39 PM
aam6906's Avatar
Sway Bar On G35x??
Does Anyone Have An Aftermarket Sway Bar Installed In There x? i heard that there are none? is that true?
Old Jan 14, 2005 | 08:36 AM
SixFive's Avatar
With the added weight and the different suspension (read stiffer) I would avoid it personally after having driven the 05 anyway. I don't believe that a sway for the X is available
Old Jan 14, 2005 | 11:05 AM
Gsedan35's Avatar
Since the front sway bar on the X has totally different bends, none of the current G or Z sway bars will mount up in the front. When I went to the dealer to specifically look at the X's front suspension I did not however even glance at the rear suspension or the rear sway bar. Assuming that the rear bar is the same, to get a stiffer front bar is easy. Simply pull the front bar, it's mounting hardware and the end links and sent everything to http://www.sanerperffab.com/products.htm and they can make you a custom copy to your specs.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
The Fixer
Nov 1, 2015 03:26 PM
Claudiu
Sep 26, 2015 01:04 PM
