2008 Infiniti g35 code p1757
Old Feb 21, 2021 | 02:25 PM
HeadTurner 555's Avatar
2008 infinti g35 base
I started my car and drove it and noticed that my car won’t go over 3k rpm and speeds up really slowly. Put a code reader and got code p1757 front brake solenoid. Do I take it to a it to a regular mechanic shop or a transmission shop?? (5speed auto)
Old Feb 21, 2021 | 02:35 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Transmission shop probably but a GOOD mechanic will be able to do this repair as well, let them know it's common for the wiring to break on the valve body right at the harness and it usually just needs to be soldered back on. Show them this picture for reference.
If the wire isn't broken it's probably just the solenoid itself that failed.
Old Feb 22, 2021 | 02:17 AM
around how much do you think a job like this would cost??
Old Feb 22, 2021 | 11:47 AM
cleric670's Avatar
BANNED!!!
No clue, might be better to just order a replacement valve body and swap it in, keep your existing TCM. Call around for price quotes, it's about a 4-5 hour job.
If that wire was the culprit and I was doing the repair myself it would cost me about $0.03 worth of solder, if the solenoid was bad it's about $50, if you end up replacing the entire valve body you can get rebuilt units for about $300. Labor is typically $125/hr.
That's a good ballpark number, most of the labor is in the removal/installation of the valve body.
Old Feb 22, 2021 | 04:59 PM
Scorpi0's Avatar
Heres a good thread for ya!
https://g35driver.com/forums/drivetr...p1759-fix.html
Old Sep 17, 2024 | 11:18 PM
99zx2turd's Avatar
i just had to go thru p1757 myself on my '07 sedan... mine wasn't a break at the solenoid circuit. All solenoids OHMed out in range except the front brake one that was 26 Ohm vs 6 Ohm on the rest of them. Went to a JY and grabbed a solenoid that Ohmed out correctly as well as a TCM. Threw both in and it appears to be shifting into 5th now. Need more test-driving tomorrow.
First Gate
Aug 14, 2020 10:28 AM
First Gate
Aug 13, 2020 08:15 PM
Karbert
Aug 15, 2012 11:58 PM
Foo_G
Oct 22, 2006 08:39 AM
