Desperately needs help with Key Fob
Old Jul 11, 2023 | 03:21 PM
fayaz arakkal's Avatar
Infiniti G35
It showed low battery for the key fob.
I changed the battery.
Now the car won't even unlock let alone crank.
mine is 2008 Infiniti G35 here in Qatar.
I changed the batteries twice and checked.
tried the rfid thing by placing the key near the push start button, no hope.
What should I do? Please advice 🥹
Old Jul 15, 2023 | 11:00 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Are you sure those batteries are good? I've seen PLENTY of brand new CR2032 or CR2025 that were dead in an unopened package.
If that won't do it then your fob itself probably died, is there a local Nissan/Infiniti, or Renault might have the Consult-III software. They would be able to program the new fob, local automotive locksmiths might have the programmer as well so call around.
You should also scan for OBD2 codes, it's probably throwing the NATS lock code.
Old Jul 16, 2023 | 11:58 AM
Mr.GEE's Avatar
20 Year Member
If everything worked before and you just received the weak battery message, you probably installed the battery in the key fob backwards. Flip the battery over and try again.
simoneam
Apr 15, 2017 05:03 PM
inthedrink
Jun 21, 2012 12:03 AM
cb4h
Nov 5, 2009 03:03 PM
johne
Nov 18, 2007 07:22 PM
03FXer
Mar 22, 2007 02:34 AM
