p1217 code, but gauge reads normal
Old May 19, 2024 | 12:20 AM
andrewsh's Avatar
2008 g35 sedan journey
I got the check engine light with a p1217 code, but the temp gauge read normal.
what does the ecu read to decide to trip this code?
I only see 1 temp sensor on the car, so it must feed both the gauge and ecu.
there was coolant in the overflow tank, but it was still hot, so will have to wait till morning to pop the top and verify.
2008 g35 journey.
I replaced all of the coolant hoses and heater hoses about 500 miles ago.
lost some coolant after the changes and got that sorted out and haven't lost any in several weeks. so I don't think it is related, but not sure yet.
but checking to see if there is some other cause I need to check as well.
Old May 19, 2024 | 09:30 AM
treacherous's Avatar
20 Year Member
G35x
Old May 19, 2024 | 12:33 PM
andrewsh's Avatar
thanks.
It appears it was low on coolant.
don't see any leaks, and I used a vacuum coolant tool, but will have to monitor it more closely now.
Old May 19, 2024 | 03:26 PM
20 Year Member
G35x
It took me a while to bleed mine when I last changed coolant. I had vehicle on ramp and added these bleeders on both sides
https://www.z1motorsports.com/z1-pro...e-p-11190.html
https://g35driver.com/forums/v36-eng...ml#post7197433
michael j
Jun 13, 2020 06:33 PM
Jon Van Luven
NorthEast
Mar 5, 2020 10:31 AM
Chort729
Jul 9, 2014 12:12 AM
evan2k
Feb 27, 2014 04:54 PM
ShanesG
12
Aug 21, 2009 11:23 PM
