G35 mod to a G37 headlight
Old May 19, 2024 | 02:33 PM
mpmiller37's Avatar
G35x
Headlight wiring question. Have an 07 G35 Sedan and I'm doing a mod of the headlight, bumper etc. to G37. As you may know, the G35 has 3 connectors that plug into the oem headlight, a small 3 prong (maybe 2) whitish connector, an 8 pin gray, and an 8 pin black. The G37 headlight (its a VIPMOTOZ) only uses an 8 pin black connector. I'm told (but would like to verify) that the G37 headlight connector pins have this functionality:
Top row left: Running, High, Turn, Low. (meaning running lights, which beam etc.)
Lower row: Ground, Ground, Open, Open
Such that the top 4 pins are utilized and 2 ground pins on the bottom
I was hoping a wiring harness adapter would exist to adapt the G35 connectors to a single plugin for the G37 light, but haven't seen one. Can someone tell me (or link to diagram) showing what the (3) G35 connectors control, i.e. using the wiring color or pin layout, so I can understand how to map the G35 wires to the new G37 headlight. Much appreciated.
Mike
Old May 20, 2024 | 11:51 PM
Scorpi0's Avatar
This is for a 2005 Sedan. Im assuming the 2007 should be the same.
Old May 20, 2024 | 11:53 PM
Scorpi0's Avatar
Heres the manual if tou need to lookup more info.
http://boredmder.com/FSMs/Infiniti/G...an/2005/LT.pdf
youngdip631
2nd Gen (V36) Sedan
May 22, 2016 05:21 PM
Jmbader8
May 28, 2015 09:31 PM
That G Gray
Jan 24, 2014 03:35 PM
vito2008
Lights
Dec 13, 2010 03:49 AM
LOLmustangLOL
May 15, 2009 03:03 PM
