Power steering noise
Old Oct 26, 2024 | 05:46 PM
Gustavo S's Avatar
It’s a 2007 Infiniti g35
I got a 2008 g35x sedan I changed the power steering pump twice I checked all the hoses and I don’t see no leak I truly don’t know what’s wrong and I can still hear the noise any suggestions on how to get rid of the noise?
Old Oct 26, 2024 | 11:11 PM
Scorpi0's Avatar
What noise?
Old Nov 6, 2024 | 06:24 PM
MaLPoPieS's Avatar
Jaguar XFR-S
I believe what he meant to say was 'pump whining' noise due to trapped air in the system.
Jack the front up, top off the tank, let the engine warm up and turn all the way LEFT, hold for 3 seconds, then all the way RIGHT and hold for 3 seconds, repeat 5x, check fluid level and if you used Ford Dexron, there should be no whine or noise unless the replacement pump is crap or you have air entering the system by having loose connections.
I've just replaced my rack and pinion and all i did was refill the tank and do above steps and pump runs quietly.
Gustavo S
Oct 26, 2024 03:43 PM
3000vr4tt
Interior
Jan 30, 2014 10:33 PM
JiHouse
Jan 31, 2012 04:57 AM
g35ivp
Jun 26, 2007 12:09 PM
