nissan data scanner 3, wakeup fail for ecm
Old Apr 24, 2025 | 04:17 PM
andrewsh's Avatar
2008 g35 sedan journey
I am hoping someone else has used this software before.
I am trying to reprogram the keys, but I keep getting an error message trying to connect to the ecm wakeup fail.
you can see in the nds video that guy gets the same message and he messes with stuff that you can hear, but no explination of what he did to clear it.
I don't seem to be able to connect with it at all.
I can connect to the bcm just fine, but ecm always gives me the wakeup fail.
nds' site doesn't seem to cover this.
Old Jun 11, 2025 | 01:22 PM
Not4ray's Avatar
Any updates on this ??? I cant even get the bcm to wake up
Old Jun 11, 2025 | 04:47 PM
Not4ray's Avatar
what video did you watch also?
Old Jun 11, 2025 | 08:25 PM
andrewsh's Avatar
so I never got the ecu to wake up, but doing the test for can-bus resistance it seems like my bcm is down. I have one on order, and will attempt it again when I get it.
I can't find the video, but nds had it on their site for instructions. shows them trying to connect and it failed. at the 52 second mark you hear a noise and they do something and it connects. according to nds, they said they turned the key on.
to test the can bus, you put a multi meter in resistence mode and connect it to the high and low can pins on the odb2 port and it should read 60. unplugging the bcm or ecu should change it to 120.
when I did it, the bcm unplugged didn't change the resistence.
Old Jun 11, 2025 | 09:19 PM
Not4ray's Avatar
i had ordered a used bcm with the same exact serial number i just haven’t plugged it in, im kinda scared too because if nats activates i cant start the car anymore. I only have one working fob and non of my mechanical keys starts the car anymore. I’ll do this test tomorrow when i get home and get back to you.
Old Jun 14, 2025 | 10:17 AM
seymore4's Avatar
m56
We can completely bypass NATS with an Uprev ECU flash if you want, either by itself or as part of a tune. PM or email me I can help you out. Seymore4 @ gmail
Old Jun 15, 2025 | 05:27 PM
andrewsh's Avatar
so I got the new bcm and installed it. didn't change the resistance plugged in or not.
can still talk to it, but can't talk to the ecu still.
have to start over on figuring out what is going on.
Texasscout
May 20, 2020 07:10 PM
NissanSportSara
Jan 28, 2009 11:45 AM
RBull
Oct 10, 2006 09:45 AM
WILD121
Florida G Club
Oct 6, 2006 09:47 AM
