'07 g35 s 6mt awd?
Nov 29, 2025 | 10:58 AM
Hi guys I'm a new owner to an older car but it's great .l love it! I jacked the rear up to inspect tires and noticed rear diff & drive axles. I thought this car is FWD. Is it AWD because it feels like FWD. ls there a way to switch it on or off? l just got the car a month ago. l know plenty about cars just not much about this car. lt was an Alabama car that l suspect PO had high flow installed. because the O sensor code stays on yet I was able get tags in CA the PO had provided valid SMOG cert. This car is LOUD. lm just looking for known info. thank in advance
Reply 0
Nov 29, 2025 | 01:11 PM
So, you got yourself what seems like a Sport 6MT. ALL 2nd gen G-35's are either RWD or AWD, I have a G-35X, so my car is an automatic (5-speed) with front diff, and clutch pack center power divider. These cars have never been Front Wheel Drive only. Also, you can NOT have a 6spd manual with AWD. Which tranny do you have? Infiniti made a lot of G-35 x's, then G-37's and G 37x's. If your car is a manual, then you have a RWD sport, which might have 4-wheel steer also!
Reply 0
