G35Driver Feedback & Suggestions NO Car Questions! For posting Feedback, Suggestions or Questions regarding G35Driver website ONLY.
'06 6mt
Old Jun 14, 2006 | 11:38 AM
CarlosM's Avatar
'06 6mt
I have a 2006 G35 6MT. I'd like to know what type engine this car has. Is it an MREV or Rev-Up ??? Are these two the same (MREV and Rev-Up) ??
Old Jun 14, 2006 | 05:06 PM
KAHBOOM's Avatar
Revup is the appropriate term. MREV is the aftermarket part designed by Tony at Motordyne Engineering. The difference in the Revup engine and the other engine options in the coupe is that it has a higher redline. It produces it's peak power by revving up vs the other engines (in the 03- 04 G's and current model AT's) produces it's peak power at a slightly lower RPM. The non-revup produces more torque however so it essentially has more power at the lower RPM's than the revup. The revup has more power at the higher RPM's than the non-Revup.
You will notice the biggest difference at higher speeds. The revup should pull slightly against a non-revup. Off the line the non-revup has a slight advantage but can be countered by a good vs average driver.
Thebaws11
Jul 2, 2021 11:36 AM
Blue Dream
Dec 5, 2015 10:56 AM
alessandro
Oct 8, 2015 09:29 AM
RWDguy4238
Sep 30, 2015 12:13 AM
