G35Driver Feedback & Suggestions NO Car Questions! For posting Feedback, Suggestions or Questions regarding G35Driver website ONLY.
Search Engine Sucks
Old 07-04-2008, 11:50 AM
Christian's Avatar
^^ heres a little bit, but if you google it you'll find more:
Originally Posted by -= SKiZO =-
Search is a bit tricky here I found also, but yes you can search on those items.
Do this:
In the advanced search page - down the bottom there is an option for "boolean search type" make sure you select that option.
Then in the search field put the term you are searching for and an asterisk at the end.
eg,
HKS*
GTR*
NOS*
If you want to search for multiple items at once use an "AND" in the middle
eg,
sex* AND gtr*
g35* AND japan
The boolean option is the key and this works good for all short search terms.
Where does the term Boolean originate from?
Boolean searching is built on a method of symbolic logic developed by George Boole, a 19th century English mathematician. Most online databases and search engines support Boolean searches. Boolean search techniques can be used to carry out effective searches, cutting out many unrelated documents.
Is Boolean Search Complicated?
Using Boolean Logic to broaden and/or narrow your search is not as complicated as it sounds; in fact, you might already be doing it. Boolean logic is just the term used to describe certain logical operations that are used to combine search terms in many search engine databases and directories on the Net. It's not rocket science, but it sure sounds fancy (try throwing this phrase out in common conversation!).
Basic Boolean Search Operators - AND
Using AND narows a search by combining terms; it will retrieve documents that use both the search terms you specify, as in this example:
* Portland AND Oregon
Basic Boolean Search Operators - OR
Using OR broadens a search to include results that contain either of the words you type in. OR is a good tool to use when there are several common spellings or synonyms of a word, as in this example:
* liberal OR democrat
Basic Boolean Search Operators - NOT
Using NOT will narrow a search by excluding certain search terms. NOT retrieves documents that contain one, but not the other,of the search terms you enter, as in this example:
* Oregon NOT travel.
Keep in mind that not all search engines and directories support Boolean terms. However, most do, and you can easily find out if the one you want to use supports this technique by consulting the FAQ's (Frequently Asked Questions) on a search engine or directory's home page.
Old 07-04-2008, 12:39 PM
OCG35's Avatar
^^^ ahh haa... thanks
Jiggerjuice
10-05-2015 02:33 PM
StephonW
08-29-2015 01:24 AM
derres
08-28-2015 03:27 PM
Quick Reply: Search Engine Sucks
