G37 Coupe V36 2008+ Discussion about the G37 Coupe
G37 Tech Specs, Features & Options
Old Mar 24, 2007 | 04:23 AM
  #31
wyatthanson's Avatar
Thanks a lot. Rear View camera, Intelligent Key, 330hp and 6MT combined confirmed my order.
Just *curious* about gas mileage.
And color combos. Fully loaded, here I come.
Old Mar 24, 2007 | 07:04 AM
  #32
SilverII's Avatar
what is the seat belt pre crash thing? Is it like the is250/350 where it would pre-tension on really hard braking? I hate that.
Old Mar 24, 2007 | 11:47 AM
  #33
FAST1's Avatar
Originally Posted by Deang35c6
The G35 is not a sports car, but a GT. If you want a sports car, then this is not the car for you. Some curb weights of other GT cars:
AM DB-9: 3968
BMW 335i Coupe: 3571
BMW 650i: 3814
Ferrari 612 Scaglietti: 4056
Ford GT500: 3920
Jaguar XKR: 3814
Maserati Coupe: 3682
Mercedes CLK550: 3720
Barring the obvious differences in horsepower, you can see the trend with GT cars...they are heavy. Performance takes a back seat to luxury features. While people are complaining about the weight, no one wants to forgo rear view cameras, heated seats, 9.3g hard drive, 11 speakers, etc. Get a true sports car like C5 or Cayman and call it a day.
All good info. Now compare those weights to a real sports car like the Porsche Cayman which has a curb weight of 2952 lbs with a manual tranny. So the G37 has 35 more HP than a Cayman S, but weighs over 700 lbs more. The extra 35 horses that the G has will no way offset the huge disadvantage of those extra 700 lbs.
Even more troubling is the relatively low torque of the G37 which is horrible for a heavy car. There may be some impressive 0/60 times quoted but they won't mean a dam thing since hardly any of us are going to abuse our cars the way that some magazines do just to knock off a few tenths of a second. If you want a real measure of the G's performance, find some magazine that provides a 5/60 MPH acceleration time. That will give you a far better indication of how the car will perform on the street, than some guy who launches the G at 6K RPM.
Old Mar 24, 2007 | 12:03 PM
  #34
muscarel's Avatar
Wow, now we're comparing a 35k car to a cayman S. Says alot about the new G.
The new G will perform circles around the old G regardless of the extra 150 lbs. The old coupe 6mt had only 258 lb-ft of torque and 298 HP (275 for the auto) compared to 270 and 330. Plus the car has a flatter curve which means more power throughout the rev range. The 5-60 will be better with the new model as well as 0-60 and 1/4 mile times. Can we stop comparing this car to the old model performance-wise? We already know it will be much better in all aspects.
Anyone notice that the final gear ratio of the new G changed from 3.538 to 3.692? All the other ratios seem to be the same. I hope they are right about improving the 6-speed making it more refined.
Old Mar 24, 2007 | 12:34 PM
  #35
Deang35c6's Avatar
Good Catch! With VVEL and 3.692 FD, and 50 hp over the 2003 6mt; the new G could perform better than expected even with the extra weight. Keep in mind that the 330 hp is under the new standards, which gets the 5AT 306 hp sedan down the 1/4 mile in 13.9 seconds. The new FD acts as a torque multiplier.
Old Mar 24, 2007 | 01:08 PM
  #36
JadeRaven's Avatar
EXACTLY! I don't understand all these folks who think their *luxury* cars are supposed to be slim and trim. If you really wanted to save weight, go for the plastic/spartan interior of the 350z, or a whole myriad of other options.
There's a reason Lotus lists the weight of the options in their brochure for the Elise.
The Ferrari F40 weighs about 2,500 pounds. You open the door with a cable.
Old Mar 24, 2007 | 01:25 PM
  #37
Cost a G's Avatar
Yup, G coupe is definitely a GT car. All the extra refinement they did to the new G coupe only adds weight as it is basically the evolution of the old coupe. They could have made it lighter, but at the same time it would only cost more.
Old Mar 24, 2007 | 01:32 PM
  #38
Sukairain's Avatar
At the rate things are going........
In 15 years the 2022 Infiniti G60 is going to weight 5000lbs, come with 30" rims, and 1200hp.
Old Mar 24, 2007 | 02:00 PM
  #39
JadeRaven's Avatar
Also, the 300ZX TT in 1990 was ~3,500 pounds.
3,500 to 3,700 over 17 years ain't that bad, considering what you get
Old Mar 24, 2007 | 02:33 PM
  #40
FAST1's Avatar
LOL The only thing being compared is the weight. The Cayman S understandably is a superior car for those who value handling above all else. Most performance cars that weigh as much as the G37 have at least 300 lb/ft. of torque. You are in for a very unpleasant surprise if you believe that 270 will do the trick. I believe the 335 has 300 lb/ft.
Old Mar 24, 2007 | 03:00 PM
  #41
RBull's Avatar
Rated M
Originally Posted by Samson
Well said. I just checked out the weights for the 2007 Sedan:
G35: 3,497
G35 Journey: 3,505
G35x AWD: 3.704
G35 Sport: 3,538
G35 6MT: 3.532
Why oh why is the Coupe quite a bit heavier than the Sedan? By rights, it should be lighter, not heavier. 3616 for the base Coupe, 3624 for the Journey and 3,668 for the 6MT. The sportiest is the heaviest. Weight is the bane of any car. As you said, we are in a vicious cycle because we increase weight, so we increase engine size and power to offset the additional weight. This continues until the car becomes a clean sheet of paper redesign. I don't like the direction Infiniti is taking.
I also would like to see a lighter car.
The same thing is true with the previous generation however. My coupe weighs more than your sedan. It is most likely some additional bracing in the car to make it stiffer, bigger suspension pieces etc.
Old Mar 24, 2007 | 03:04 PM
  #42
RBull's Avatar
Rated M
Originally Posted by Hybrid_DET
It seems every year a G hits the streets, it gets heavier even though they increase horsepower output. So you increase weight and add horsepower and you are back where you first started. I don't get it either.
This is also true of virtually every make and model of car. It's the way it works in auto marketing 101. Cars get larger, heavier and more expensive each succesive change keeping some original buyers in the fold as they upgrade. Then a new model is eventually launched to fill the void of the original version.
Old Mar 24, 2007 | 03:06 PM
  #43
RBull's Avatar
Rated M
^+1
Well said.
Old Mar 24, 2007 | 04:47 PM
  #44
lostsk8r's Avatar
ahhh <3 9.3 gigabyte music box hardrive
Old Mar 25, 2007 | 12:08 AM
  #45
Queenskid24's Avatar
Originally Posted by vstrizheus
I believe a Sunroof is not seethrough, it is metal, and a Moonroof is glass.
You pretty much hit it right on the head. Sunroof is a term that used to be used before to describe solid panels which slid back on the roof of cars to let light in, obviously sunlight. Moonroof is basically a sunroof, only that now its glass.
