2008 Infiniti G37 Coupe
Base Price $35,000 (est)
Vehicle Layout Front engine, RWD, 4-pass, 2-door
Engine 3.7L/330-hp/270-lb-ft DOHC 24-valve V-6
Transmission 6-speed manual, 5-speed automatic
Curb Weight 3600 lb (MT est)
Wheelbase 108.3 in
Length x Width x Height 182.1 x 73.0 x 54.0 in
0-60 MPH 5.2 sec (MT est) auto 5.5
EPA City/HWY Econ 20/27 mpg (MT est)
On Sale In U.S. August 2007
Wheelbase 108.3 in
Honestly, how can they possibly think its going to be only as fast as the 07 Sedan? 07 Sedan has 306hp, this has 330, and the weight difference is negligible .
Quote:
It will probably be slightly faster but I wouldn't expect much. The weight is about 3-4% more than the sedan. Torque has no peak gain, broader curve and peak hp up about 8%. Gearing has changed which may have the largest bearing on any change in acceleration.Originally Posted by vstrizheus
Quote:
Agreed... I doubt any official testing gets to 60 in under 5.Originally Posted by RBull
I think the mags will be running 5.0 and people will be hitting 4.8 - 4.9 but thats me
Quote:
Actually it's generally the other way around. The guys who do the testing for the magazines are quite good since they drive cars hard all of the time. Moreover, they will run multiple tests at various RPM launches until they get the absolute fastest run from that car. Car abuse means nothing to them since they don't own the car. Finally, most magazines will adjust for conditions. So if the temperature is really hot or they test at a high elevation, some time will be subtracted from their test drive. Originally Posted by vstrizheus
Bottom line is that for most magazines, the time posted will be really tough to exceed unless you use some measuring device inside your car that is no where near as accurate as the guys use at the magazines. A much better indication of the performance that you can expect to get from your car comes from the manufacturers.
