G37 Coupe V36 2008+ Discussion about the G37 Coupe
Coilovers
Old Jun 11, 2021 | 01:18 AM
Zack Allen's Avatar
g35 coupe
Coilovers
I have coilsovers for an 03 g35 coupe and I was wondering if the would work on a 08 g37 coupe. I know the spring ratio is different but would it still be possible to use?
Old Jun 11, 2021 | 11:30 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I've always heard that it is NOT interchangeable but I've never compared the two to see why.
Old Jun 12, 2021 | 10:57 AM
Zack Allen's Avatar
g35 coupe
the difference I heard was that the spring ratio was different
Old Jun 12, 2021 | 11:21 AM
cleric670's Avatar
BANNED!!!
I highly doubt it's because of spring rate, every coilover has different spring rates and they vary WILDLY from very soft to very VERY VERY stiff.
It's more likely that the overall length is quite a bit different but on coilovers you might be able to compensate for that by just raising/lowering to make up the difference if it's not that much. But if it was that easy then it would probably be more widely known that this was the issue.
I suspect there's some kind of mounting difference, like the bolts on the strut aren't the same bolt pattern or something along those lines.
leanlikeacello
Sep 7, 2014 04:36 PM
Gedan35
V36 Brakes, Suspension, Wheels & Tires
Jan 30, 2011 11:04 AM
Lou@amplified
Aug 21, 2008 02:15 PM
