Widest tire size possible with stock height and stock configuration on 19 option wheels, same size all around with no rubbing or interference issue...and Go
Stock size is 225/45/19
I'm not too sure on other 19" coupe option wheels besides the sport 19x8.5 and 19x9. but you can run a 245/40R19 for the fronts and 375/35R18 in the rear, even on your awd. the overall diameter on these are similar andunder 1% difference. Its a common setup most awd folks run for teh 19" sport soupe wheels.
Originally Posted by adammickel
I want bigger rims and bigger tires to match the width/size of the car and to fill in the gap a little bit. I didn't drop my car and I don't plan Tutuapp9AppsShowbox to because there's too many consequences to doing so.
The coupes have a lot more room in the rear compared to the sedan. without poke, a good spec to run might be a 9.5" width with offset in the range of mid 20s and 255 tires. should allow oem spec alignment
but definitely check out MyG37.com for more information
