G37 V36 Sedan 2009 + Discussion about the G37 Sedan
2010 G37x AC/heater blower not working
Old Mar 24, 2023 | 06:00 PM
G37XFlorida's Avatar
G37X
Car won't blow any air warm or cold from vents. Tried replacing fuses, relay, and blower motor. Recently had alternator and serpentine belt replaced and issue happened after short time after that but shop said no need to reset ECM or anything. Any ideas on what to try next?
Old Mar 27, 2023 | 11:02 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Are you SURE you replaced the relay? It's a common failure item and it's located BEHIND the cabin fuse box.
Unbolt the fuse box, lift it up (there's not very much room due to the wiring harnesses) and you will see some blue relays stabbed on the back of the fuse box, here is a picture of the layout for your 2010 G37.
cleric670's Avatar
BANNED!!!
It's the one called "blower relay"
G35 NL
V36 Audio, Video & Electronics
Jun 6, 2019 12:48 PM
esotericrider
Jul 6, 2016 10:24 PM
master111
Sep 25, 2015 08:32 PM
Adrian90744w
Feb 8, 2013 09:35 PM
BBG35X
Jun 24, 2012 03:41 PM
