I have new to me a 2010 G37X that ifI get it up to 100 kph (60mph) I get a drone in the car seems to me its coming from the back. IT gets loudest at 110 kph and then seems to taper off above 120 kph. I lifter there rear wheels and spun the tires and the bearings seem to be quiet and smooth. I do not get any vibration from the car.
Very annoying. Hopefully someone can help. Im at a loss
The sound is like a low exhaust rumble. I did shift gears at speed and it’s not exhaust or engine. Even under throttle as you pass that speed it is there not just at cruising
Urbanengineer
close
- Join DateJun 2013
- LocationOH-IO
iTrader Positive Feedback100
iTrader Feedback Score(3)
Liked:1,045 Times in 960 Posts
Often issue with aftermarket exhausts. Do you know what’s on it?
