G37 V36 Sedan 2009 + Discussion about the G37 Sedan
Running rough at 30mph low rpm
Old Jan 30, 2025 | 06:27 PM
dandor268's Avatar
5 Year Member
Hi
I've had the car 4 years or so, this is the first winter that I've noticed when my Automatic 2014 Infiniti Q60 S (54,000 miles) is driving at about 30 mph, it sounds and drives rough. The best way i can describe it, is if it's not getting enough gas for the gear that is automatically selected.
Cruising at 30mph the RPM is low, around 1000 rpm. If I accelerate to get out of that gear, the issue is gone. If i use the paddle shifters and control the gears myself, i cannot reproduce the issue. It's almost as if the automatic gear shifting is putting it into too high of a gear for that speed. There is no issue at idle either. On the rare days it's warmer, there's no issue. If related, I did clean the throttle body a couple years ago using TB cleaner, which resolved and issue of the car dying in idle a few times.
Could i ask for some technical advice? I'm limited to 30mph due to a speed camera and the car is in fantastic condition.
Old Feb 12, 2025 | 09:45 AM
dandor268's Avatar
5 Year Member
I disconnected the battery for 2 days, and also test drove without both filters installed. The issue continues. Any ideas?
OneSlowG35
May 19, 2023 12:36 PM
MVMNT
Jan 14, 2016 07:47 PM
vdoh8687
Mar 20, 2012 08:32 PM
direngreyt
Aug 2, 2011 08:01 PM
