General Media Share Find and share Infiniti-related videos! Just took some pics for fun? Looking for general pics and vids? Try it out. Please post specific media (Mods, etc.) in its specific category in the Tech Area.
Mini photo shoot of me with my G from Z Nationals 2012
Old Oct 11, 2012 | 01:45 PM
  #31
Golden_Shower's Avatar
Originally Posted by My Key
if you say so. I think we need more pictures of her headlights to make sure
Honestly I would need first hand experience to see how fitment is to give you an honest answer.
Old Oct 11, 2012 | 01:47 PM
  #32
ishiftinheels's Avatar
Teh Redhead Moderator
OEM.... not JDM though
Old Oct 11, 2012 | 01:50 PM
  #33
My Key's Avatar
I agree with your assessment. I hear you are quite the expert in that field.
Old Oct 11, 2012 | 01:51 PM
  #34
I have worked on my fair share of headlights, I find the JDM ones to be a bit on the small side and are alot harder to work with since I have big hands.
Old Oct 11, 2012 | 01:54 PM
  #35
My Key's Avatar
Oh, while you're at it, i suggest you check the fitment of the rear bumpers.
Old Oct 11, 2012 | 02:00 PM
  #36
Normally if the fitment on the headlights is firm the bumper tends to be the same, but there odd cases where the headlights are great and when you check the bumper its gone.
Old Oct 11, 2012 | 02:02 PM
  #37
My Key's Avatar
Make sure the undercarriage is not sagging as well
Old Oct 11, 2012 | 02:06 PM
  #38
Undercarriage is pretty much out in the open so its either good or bad. I like to make sure the muffler is clean and not covered in mud, had a few bad experiences if you know what I mean.
Old Oct 11, 2012 | 02:08 PM
  #39
My Key's Avatar
mud on the exhaust could ruin a good run. Check the intake too to make sure there's no leak and it has good suction
Old Oct 11, 2012 | 02:12 PM
  #40
Depends if it's a FI model or not, if it's a FI > NA because suction is insane at full boost, but sometimes NA gets the job done.
Old Oct 11, 2012 | 02:15 PM
  #41
My Key's Avatar
which reminds me, make sure there's no oil consumption or leaks in the cylinder. Make sure it has a tight seal when doing a compression test.
Old Oct 11, 2012 | 02:17 PM
  #42
Better yet check to see if it has been bored out to a larger size or not. I always prefer to lube the piston first, shoving a piston into a dry cylinder can cause alot of damage.
Old Oct 11, 2012 | 02:21 PM
  #43
My Key's Avatar
which oil do you use to lube the cylinder? High viscosity or low viscosity? Make sure it handles well under a huge load. Do you sleeve the piston before putting it in the cylinder?
Old Oct 11, 2012 | 02:23 PM
  #44
If it's a clean cylinder, I don't bother sleeving it, in the rare case that they cylinder is blown out I always sleeve.
Viscosity is a totally different ball park. Sometimes the cylinder is self lubricating and other times you just have to spit on it to get the piston in.
Old Oct 11, 2012 | 02:25 PM
  #45
My Key's Avatar
See how the ride is. Check if its stiff and remains relatively still or if it goes crazy and bounces around a lot. Also see how loud the car gets when you drive it aggressively.
