Battery Problems?
Old Dec 26, 2006 | 02:49 PM
35Blaze's Avatar
Battery Problems?
Does the G use up a lot of battery power during normal everyday use? I bought my first battery about 2 months ago. That one died about 3 weeks later so i returned it and now this one died about a month later. I brought the car into Infiniti and they cannot find anything wrong with the charging system or the wires or anything. Could it be that i just bought a battery brand that cannot support the G? Has anyone had this problem?
Old Dec 26, 2006 | 02:58 PM
Rphillips6487's Avatar
Ive had my G35 since mid september and Ive had no problems with mine but who knows maybe once a few more people post we'll see if its something common
Old Dec 26, 2006 | 03:01 PM
Daehtihs's Avatar
You must have something drawing voltage. I'd take it to an independant garage that you can trust and fill them in.
Old Dec 26, 2006 | 03:42 PM
Mike_Deezy's Avatar
What year is your car? I've had my '04 for a little over 2 years now and I haven't had to replace mine yet.
Old Dec 26, 2006 | 09:45 PM
SFG356MT's Avatar
No problems here either and I run a laptop with the engine off from time to time for periods of over an hour.
Old Dec 26, 2006 | 10:34 PM
gspotter's Avatar
What kind of battery are you using?
Old Dec 28, 2006 | 03:09 AM
35Blaze's Avatar
Mines an 04. Forgot the name brand but it was only $50. ill check the brand. The thing that gets me is that i brought my car to the dealership and they found nothin wrong with the alt, wires or any charging system and checked for shorts too.
Old Dec 28, 2006 | 04:03 AM
Fassster10's Avatar
i've had my G since 03 and never had battery problems...
Old Dec 28, 2006 | 10:39 AM
partyman66's Avatar
I've had mine since 2004 and my battery sounds kinda weak lately when I start it up. I'm probably going to replace it with an Optima battery if it gets worse(which it probably will).
Infiniti must just give us real crappy OEM batteries... but it doesn't sound like the battery is the source of your problems unless they just charged your battery up and lied to you, telling you they replaced it.
Old Apr 3, 2007 | 12:15 PM
carbertk's Avatar
I've taken my 06 G35 sedan in a few times now. I travel often out of country and my G sits for a couple weeks at a time. When I get home the car is stone dead. First time they said it was the remote command start, disconnected it, next trip, presto, battery was dead again. Took it in this time, now they say the radio is draining too much so have ordered a new radio. Will let you know if that fixes the issue. Anyone else have this problem? Remember car needs to sit minimum 2 to 3 weeks without starting.
Old Apr 3, 2007 | 12:23 PM
LjN_728's Avatar
Take your alternator to Pep Boys and have them run a free test.
Old Apr 3, 2007 | 12:33 PM
r0csfinest's Avatar
im starting to have problems with my battery too now. i have a 05
Old Apr 3, 2007 | 03:07 PM
BadBoy06's Avatar
maybe a bad batch of batteries from the start.
had that prob on another car.
Old Apr 3, 2007 | 03:16 PM
Texasscout's Avatar
Mine is over two years old and no problems, I even have ham radio gear and blue tooth hf in the car. I suspect like others here, you have something drawing the battery down. You need to have someone check how many milliamps are being drawn off when it sits. I know there are a few used to maintain the computer and radio settings, but it shouldn't be much. Also, you need to check to see if your battery is being OVER CHARGED. You should not have more than 14.5 volts while it's charging, once it has charged, it should drop to around 13.5 plus or minus 1/2 volt. If it's over charging, it's boiling the electrolyte.
Also, it doesn't take more than 2 or 3 discharges to zero volts to ruin a battery. Damage starts once it reaches 10.5 volts and the longer it stays that way, the more damage (calcification of the plates) takes place.
Old Apr 6, 2007 | 09:14 PM
nchima's Avatar
lol
