Burnouts: VDC Fuse? Brake Fuse? ABS Fuse?
Old Jun 4, 2008 | 09:57 PM
  #31
Aced16's Avatar
Originally Posted by billybrun
Well, on my car there are two push switches on the brake pedal. The higher one being the one for the brake light. That's the reference that the ecu uses to cut the throttle if both brake and gas are applied at the same time while the tires are spinning at a higher rate than the front. I used a kind of OEM looking lighted switch along with a relay to bypass that signal on command, like at the dragstrip. There are no lights or faults associated with this when I hit the switch, because all I'm doing is bypassing that push switch.
It rained this morning so I went out and tried it, and it works perfectly. Hit the switch, hold the brake firm and gas at the same time with your right foot (around 3500rpm) then dump the clutch. The car shouldn't move.
I have some pictures of the process if somebody want to see them.
i know this is a resurrection, but can you post the process for us PLEASE!!!!
Old Jun 5, 2008 | 11:00 AM
  #32
ttrank's Avatar
Grocery getter
Just look under there. You will see two pin switches on the brake arm. Pull the plug on the top one.
Old Jun 5, 2008 | 04:47 PM
  #33
billybrun's Avatar
Sure, look in here... https://g35driver.com/forums/drivetrain/161288-burnout-switch-mod.html
Old Sep 19, 2008 | 02:48 AM
  #34
edwpor's Avatar
i see but were is the abs fuse located ??? under the steering wheel or by the battery ????
Old May 18, 2024 | 03:34 PM
  #35
I_luv_phatgurlz's Avatar
Base G35 Sedan
I give up
Not doing this anymore
Last edited by I_luv_phatgurlz; May 19, 2024 at 11:30 PM. Reason: Wrong information
2014g35x
Sep 11, 2015 07:53 PM
GMoNeYAir23
Engine - Electrical
Sep 11, 2010 02:43 PM
srmfball
Mar 19, 2007 10:10 PM
