best band for the buck investment?
Old Aug 12, 2008 | 05:10 PM
noir_qc's Avatar
hi all ,i have 1k to invest in my g35 coupe 2003 AT anf i would like to know what would give me the best bang for the buck....i searched the forum and found a thread about a y pipe and MD plenum spacer....is it a good way to spend my 1k? and was wandering bout the mrev2 intake of motordyne....so the list i was thinking bout is motordyne iso thermal 1/2 plenum spacer,mrev2 intake and megand y pipe ..... i would like to have some suggestion....thanks
Old Aug 12, 2008 | 08:43 PM
kenchan's Avatar
is that on stock suspension? should upgrade that first.
Old Aug 12, 2008 | 09:52 PM
pattyskin's Avatar
If you are looking for acceleration I believe changing your final drive would give you the biggest gain in acceleration for about 1k. I personally would use the 1k to do something like replace the stock hu with a DD nav unit or something of the sort though since this is a benefit which you will see and use every single day.
Old Aug 13, 2008 | 09:58 AM
twin001's Avatar
Typically with exhaust you want to work your way from the back of the car to the front. Get the spacer and look for a used cat back exhaust. This will make your car sound better but you will really need a tune to get the most out of the mods. Search through the threads and you will answer most of your own questions.
Old Aug 13, 2008 | 06:10 PM
noir_qc's Avatar
i'm looking for power upgrade and yes the suspension is stock....so a spacer and a cat back exhaust would be a good start??? what exhaust brand u recommand?and by the way can i use 1/2 spacer and still put the engine cover on or do i have to modify it to fit?
Old Aug 16, 2008 | 12:28 AM
Hydrazine's Avatar
If you have the G35 sedan you can keep the engine cover on.
If you have the G35 coupe it won't fit.
Old Aug 17, 2008 | 09:59 PM
noir_qc's Avatar
thanks all t
hanks hydra
Gabe83714
Oct 6, 2015 06:40 AM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
gatorglaze
Sep 19, 2015 12:06 PM
twentyeggs
Sep 11, 2015 03:58 PM
Hawk196
Sep 10, 2015 10:37 AM
