vdc/traction control problem
Old Aug 24, 2008 | 02:09 PM
rh_334's Avatar
i have a 04 6MT and im having a problem with my traction control "pulsing" like it does when it is activated but it does it anytime i come to a stop if it is under 80 degrees outside or if its raining. it will pulse up to about 10 times during a standard stop and i can feel the brake pedal moving a little every pulse but you hear that noise that the traction makes when it engages. well yesterday i was driving in a storm and the roads where soaked and when i got on the interstate i got in it to merge and i started spinning when i got 2nd and i slid sideways for a sec or 2 then the trac came on and defueled but the slip light never came on! but at times the slip light will come on when i am not spinning and it will defuel just going down the highway but 90% of the time the slip light does function properly. does anyone have any ideas what my problem could be? does the system have wheel speed senors on each wheel? could it be one of them?
Old Jan 11, 2009 | 09:39 PM
rh_334's Avatar
anybody? i have replaced my G sensor and my ABS unit and the problem is still not solved and i stilll have a vdc/slip light all the time and cipher will not read my abs unit it says something about a problem reading the numbers and a friend with a 04ZTT is having the exact same prob and cipher wont read his either
Old Jan 16, 2009 | 03:45 PM
g35tech's Avatar
is your car lowered
Old Jan 16, 2009 | 03:50 PM
rh_334's Avatar
it is now but it was bone stock when the problem started
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
derres
Aug 28, 2015 03:27 PM
erickLA
Aug 18, 2015 04:46 AM
TreeFiddy
Aug 10, 2015 06:50 PM
