Sunroof Problem
Sunroof Problem
Hey all. got my 2003 6MT a few months ago... everything A-ok. now I am having an odd problem with the sunroof.
Ok so on the sunroof button you can press the back of it and the sunroof retracts into the roof, that works just fine.
then if you press the front of the button, the back of the sunroof pops open a few inches like this "/"
ok so the problem is, when i press the button to get the sunroof to close from the "/" position, it always used to work fine, but now when I press it the sunroof closes to "-" then immediately pops back open to "/".
The only way i can get it to close from "/" is to double tap the button to make the sunroof lower down centimeter by centimeter, and then when it lowers the final amount it stays instead of popping back up. But if I just press the button like I used to, it closes and instantly re-opens.
Any ideas on this one, guys?
Thanks
Thanks
bump...
still happening and making me angry
if i press the button to close the sunroof, it closes then instantly pops back open. I have to trick it into fully closing.
grrr
grrr
