heater not working
Old Dec 21, 2009 | 04:29 PM
IrockAG35's Avatar
Ohio G Club moderator
Originally Posted by joealbergo
Well I just wanted to reply to your post.
There are 3 more posts with this same subject - the links are searchable.
"heat" "cold heat" "heat cold when idle" "heater not working"
I have had my car at the dealer twice.
They flushed/filled the coolant twice.
My car still doesn't stay warm after about 5 - 10 minutes of idle.
I think that this is just a rediculous issue and it can not be fixed.
I have reason to think that this is something they engineered incorrectly .
We are the only people on here talking about it because we are the ones dealing with the blistering cold and the "cold-idle heat issue"
I hear what your saying about using the proper coolant. However I am sure Infiniti dealer's have the right coolant.
I just think they "f**ked up" this on the Engine/Coolant system and that is it.
I have had this system done by the "PROS" and it is still not 100% sufficient.
The car is 5 years old it has 51k miles on it and quite simply I think "hey, it's just the way it is when a car ages"
I may be mistaken or maybe incorrect and just not knowledgable - however I have tried to take the proper procedure and results are null.
So - please do respond. I am just hear to absorb and learn and am greatful to your response.
It's just not changing the resolve of my issue..
-Joe
change he thermostat..could be bad or defective..when you do this drain all coolant and run car with new thermostat and water in rad. for 10 mins,then drain and replace with coolant..then bleed lines of air either by "bleeder" or simply running car with rad cap off until air bubbles have left rad.
Old Jan 5, 2010 | 04:55 PM
ERILUDE's Avatar
Alright I just started having this same problem. Hell everytime I get to a light I put it in neutral and rev it to 1500 rpms. After driving it for 45 mins with my engine temp at normal(half way) I opened the rad cap but the fluid didn't bubble or do anything. This seems kinda odd considering it should be bubbling!?
Old Jan 5, 2010 | 05:45 PM
GrocryGettr's Avatar
Your fluid should only bubble if it's boiling! Read my post on the first page.
arora_g35
Apr 16, 2026 02:52 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
joedaddy1
Jul 28, 2015 02:58 PM
attarday
Jul 15, 2015 04:03 PM
