Codes U1000 and P0462
Old Dec 26, 2008 | 08:40 PM
MotoCARR's Avatar
G35 Sedan
Gotta love it when your car turns on lights for you for the holidays.
U1000 CAN Communication Circuit
P0462 Fuel level sensor circuit low input
Anyone's Z/G throw these codes before? Aparently there is a TSB out for the U1000 that covers a wide range of Nissan/Infinity vehicles 2002-2006, TSB 06004.
A little debrief:
Left a restaurant Xmas eve, VDC, Slip, AWD lights were on, gear indicator and tach did not work, car shifted a little harder than normal. Drove it the very short distance home, and proceeded to do the "Air Bag Light" reset. The lights went off but then the check engine light came on. Took the car for a quick spin and AWD, VCD, Slip worked normally. Xmas morning, fire it up, lights come on, do the air bag light reset and they go out, and I start the 4 mile drive to my parents. 1/2 way there, lights come on, CEL is still on. Leave Xmas night, start the car, only the CEL. Go home, then the video store, then back home, car drove fine, just the CEL. Get in the car today to go get breakfast, car just cranks, but does not run. Airbag light reset no longer works. Went and got two OBD2 scan tools, and pulled these codes.
Aparently CAN stands for Controller Area Network and it's basically two wires that all the other computers connect to when the car does a "system check" when the key is turned to IGN. Based on the TSB, just the ECM grounds that need to be cleaned and re-grounded. Only thing that concerns me is that I have tried two scan tools and neither one is able to clear the codes.
Help/Suggestions? Going to be checking fuses tomorrow morning.
Old Dec 27, 2008 | 01:00 PM
ELMACHOGERACHO's Avatar
have you checked your neg batt cable? i have had several g's and m's with that same code recently, and most have been either a weak battery or corroded neg cable.
Old Jan 1, 2009 | 12:19 AM
MotoCARR's Avatar
G35 Sedan
Yes I checked them and cleaned them off just incase. I've been reading around and some on NICO say that there could be something behind the radio seeing as how I just installed an AVIC D3 and since my G has navi, apparently that means it's extra cramped behind the radio.
Old Jan 13, 2009 | 11:45 PM
Groove_D's Avatar
Take it to the dealer big guy, get ready to pay lol
Old Jan 14, 2009 | 01:12 AM
MotoCARR's Avatar
G35 Sedan
Naw, found out I still have powertrain warranteeeeee left
Old Mar 2, 2016 | 01:40 PM
jquisbert's Avatar
Guys,
I have replaced the entire fuel pump assembly on my 2007 G35 coupe and I still get the P0462 error. How can this be if the whole assembly comes with a new Fuel Level sensor?
Old Oct 16, 2017 | 03:13 PM
Labolanta34's Avatar
Originally Posted by jquisbert
Guys,
your cluster is bad
Old Oct 17, 2017 | 02:25 PM
telcoman's Avatar
Veteran: Army
Guys,
If the problem is in your wiring harness just replacing parts is not going to resolve your problem.
Did you use OEM parts or some other piece of cheap crap?
Did you ever consult the FSM?
http://www.nicoclub.com/service-manu...7_G35_Coupe/ec
Telcoman
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
